Thinking about putting my Spartan locker in my 94 tomorrow. Does the rear diff cover use a gasket or just rtv sealant?
There is a paper gasket, but many just use a thin layer of RTV
RTV doesn't allow the surfaces to move, so has better performance on rigs that see hard use.
As it was explained to me by Tools R Us, the paper gasket compresses, which lowers the torque on the bolts, which are not under high torque to begin with. Then the gasket moves around. With RTV there's nothing to compress- the metal surfaces come together, the RTV seals any imperfections. Plus the RTV isn't slippery at all when dry, it acts very much like glue, and it's very difficult to shear a joint with RTV. In any case, I've had issues with gaskets, and none with RTV.That's debatable. I've heard the opposite opinion. RTV is flexible, slippery stuff, I can see how it could allow movement in a high torque scenario (Not sure this application is highly torqued though).
It's reasonably common for 80s front diffs to leak at the third/housing flange due to movement and nuts loosening.
I upgraded studs on mine to 10mm hardware after getting recurring leaks with both paper and RTV used (separately)
