"I should add that I bought a repair kit, but it seemed designed to only fix the type of rear defroster problem caused by a complete break somewhere in one of the lines. I returned the kit because it looked like all of my traces were fine and that I'd either need a lot more conductive material (to replace the wide areas near where the power comes in) than what came with the kit or I'd need to go to a professional."
Ok, finally got around to looking at this. Most likely your wires running along the glass have been broken. I think I broke mine by loading crap too high that hit the rear window. It is very hard to see the breaks. They are not always visible, hence the test below.
You will need to test the rear defrost per the FSM. This involves a volt meter and piece of aluminum foil. You hook up the (+) probe of the meter to the DS plug, i.e. the positive end of the system is on the driver's side in my 1997. Wrap the aluminum foil around the tip of the (-) probe and run it along each of the horizontal wires. If you follow the FSM, you can easily find where the wire is broken. It is a bit complicated for me to explain from memory, but not too hard for this 1-. I just marked the broken wires with a Sharpie for later repair.
I was able to find a defroster repair kit at pep boys for about $12. One day this weekend I will get around to using it, erase my sharpie marks and post results.
