Rear Defrost Relay
Denver Colorado
So its getting pretty cold here in Colorado, this morning i pressed the rear defrost button on my 94 TLC. The light came on but the rear window did not defrost. Is it possible that the relay is bad and if it is, would the defrost light come on on the dash? Or could there be another issue?
Thanks
Sent from my MB886 using IH8MUD
Thanks
Im also wondering...Im plagued by this as well
There is a relay inside the kick panel, open your drivers door, pull up the plastic trim, go carefully as not to rip things apart.
Just fixed the same problem, mine fell out!
Will the rear defrost light come on even if the relay is bad?
Thanks much for the help
You should hear the relay click when you activate the defrost switch.
Once you are sure that the fuse and relay work...test for continuity of your rear window grid.
After that you decide if it works(clears the frost) or if the grid requires repair.
Use search, a strip of tin foil will help for the grid test. By running the foil along the grid you will be able to trace weak spots for repair.
There is a mention somewhere about full kits
mines doing the same thing !
Which relay is for the rear defogger?
On the 93-94 FZJ, they are located inside the driver side kick panel.
Ok I have a 97 TLC and it has like 5 of similar looking relays which one is the rear window defroster
Question: If you have power at the back window but the rear defroster doesn't work at all, does this mean that all the "lines" across the window are bad?
