Hi Folks,
This just a brainstorming thread as it is unlikely I'll get around to doing this any time soon. I plan to make front and rear receivers for receiver winching. I like the idea of leaving the winch at home for grocery getting and taking it along for wheeling trips or in rough weather when I might have to pull a neighbor out of the ditch. I also love the idea of being able to winch forward or backwards depending on the stuck. Not spending a grand or two on bumpers is a plus as well.
Anyhoo, moving on to the topic. I don't want a traditional receiver due to the crappy departure angle. My thought was to cut out some of the factory cross member and weld the receiver tube in with a bunch of gusseting to strengthen for side pulls, etc. Do you think the factory cross member is strong enough to take these kind of loads?
The other option would be to remove the factory cross member all together and build a new one (plate at the frame attachment, heavy box tube at the cross member and plenty of gusseting both at the frame plates and receiver).
I'm certain I could build something up to the task, but if the factory cross member is strong enough, that route would save a lot of work. I know either way I'll never be able to legally rent a trailer, etc. Don't care.
Your thoughts would be appreciated.
:edit: see post #10 for update
heavy. So plan on staying healthy enough to move, lift, and install them for use them like that. Like any receiver mount, there can be a bit of flopping and canting according to how close of tolerances exist.
