I built one that required cutting a 2 1/2" hole in the rear frame. Christo has told me that he makes one almost exactly like it. (I thought I was original!) I braced mine diagonally to where the tire winch used to mount. I tow from 1/4 to 1 ton most days with no problem.
My 80 gets used pretty hard. It is a work truck all week, and hits the trail about every third weekend. I have put 50k miles on it in 3 years. It has a trailer on it so much of the time that the trailer is like an amputated leg when it is not there. I still feel it! The hitch is almost identical to Christo Slee's except for the angle iron braces leading foreward diagonally to the tire winch crossmember mounting holes. I would offer pics, but the computer that does that is in the shop.
Suffice to say that my hitch is a 2" receiver tube welded to a plate. The plate bolts to the stock pintle holes in the rear frame. It mounts flush. I cut a 2 1/2" square hole in both layers of the rear frame by drilling 1/2" holes and cutting between them. I have to reach under the back of the truck to put the pin in the receiver tube. Here is the key: I bolted a plate onto the foreward end of the receiver tube, and two more plates at the tire winch mounts. Then I welded angle iron diagonally between these plates. This prevents flex in the rear frame. As if that wasn't enough, I also welded on 3/16" plates onto the angle iron braces, and bolted them onto the stock threaded holes in the rear frame. They act as skid plates when the rear lands on rocks. I left a small gap in the rear center so that I can access the hitch pin.
