On a weld that you are attaching different thicknesses of materials, your weld is frequently determined by the thinner of the two materials. In a butt-joiunt as you have here, it would have been best if you beveled the back of the 3/4" piece first in order to provide more surface area for weld to the 3/16" plate. Then you could have completed the weld in a single pass. On carbon steel, a fatter, thicker weld does NOT indicate a better weld. It is all about the penetration (isn't it ALWAYS?) The correct weld for this application would have been about 1/4" out from each piece with a nice 45° angle that is "flat" between the two surfaces. Also, when you are running a MIG welder, I recommend that you PUSH the wire rather than PULLING it. This way you keep you heated puddle out in front of the weld and you can control it a bit better. A correct wire feed weld does not require and "weave" or "circular" motion when welding.
Inspecting your welds here, they are a bit cold. The wire feed was too high for the voltage (or the voltage was too low for the wire feed speed), as indicated by the "rounding" of the weld between the two surfaces. You can also see the the portion of the weld that is on the 3/4" piece really rounds down into it. When you welded it, you should have turned up the voltage a bit and focused the nozzle more on the thicker part, as it acts like a heat sink and pulls heat away from the joint. This joint can be completed in the flat or horizontal position. If you choose to complete it in the vertical or overhead position, the joint must be slightly reconfigured.
If you really want to know how it is supposed to be done, you should follow AWS D1.1 Structural Welding Code -Steel. What did the Engineer of Record (EOR) state for the correct weld? Did it require full-penetration? Partial Penetration? Any radiography? I would designate the correct prequalified weld for this joint as GMAW BTC-P5-GF.
ANYWAY, all that BS aside.... Your welds look fine for your application. If you tear it off, pick up the pieces, grind them off and weld it back on again. All the crap I spewed there is the "legal version" of the structural code and usually only applies in engineering critical applications. If you were re-welding your frame, I would be a bit more critical of it, since that is a safety issue for when you drive down the road. I grew up on the farm running a stick-welder and burned it in until it looked good. Then grind it off to dress it up.If you tear it off, now you'll know what you can do to make it better!
Now... take it out and WHEEL it! Even if that means to the mall!
