Rear Axle question
Columbus, OH
I decided to fill my rear differential with some Amsoil 75w90 synthetic to see if it will quiet down the high pitch hum I have at 60+ mph.
Upon returning from the store, I removed the filler plug, and it made a hissing noise. Does this mean that the breather is plugged, or does the breather allow a certain amount of pressure in the axle. Update: Breather was rusted and plugged. I took it apart and cleaned it up. I will probably order a new one from C-Dan.
Second, the magnet on the drain plug was covered with a really fine dark gray sludge. When I rubbed it between my fingers, I could not feel any grit. Should this be expected?
Thanks in advance for your input.
Everything I've read indicates that metal shavings up to the size of a small fingernail clipping are acceptable - and that is why the big magnet is there. I've only ever seen fine metal shavings that looked like fuzz (and always dark black, despite the fluid looking nearly new on some occassions).
I don't know about the hiss, I've never heard that. How full did you fill it (until running out the filler hole, or ???).
Do you have an e-locker or Aussie locker or other?
Do yourself a favour and cut off the breather cap, these are known to plug.
You can still drive but stay out of deep water until you complete a diff breather system.
PS cut all our you caps off...
It is easy to extend your breather line up into the driver side rear fender well with rubber fuel line tubing. Take the old breather hose off and be sure to push a wire down into the diff breather fitting to break any crusty plug that may have formed there. Then use a cheap fuel filter (old VW or lawn mower paper type; Walmart sells them) and drill a hole up into the area where your jack is stored. Run enough fuel line from the breather fitting up inside the jack area remembering to leave enough slack for diff movement. True IH8mudders will spray paint the hole to wart off rust and also tape foam around the filter to keep it from making noise.
You want to fix this problem because that escaping pressure is pushing diff oil into your outside hubs and the oil will actually wash out the grease in your rear wheel bearings.
