On my 1976 FJ40 I have a new rear sill, repaired rear doors and have replaced the weatherstripping on the back with OEM, new paint etc. etc.
I put the new weatherstripping on about two years ago. The left door will close just fine on the ambulance doors but the right door was extremely hard to close. So I loosened everything up as best I could and got the door closed and left it for about a year thinking that the weatherstripping would seat and compress a bit. But upon opening it it still was impossible to re-close.
I noticed that the bottom is where it drags, so much so that it pulled the weatherstripping away from the metal so now I have to reseal it.
My question is – are there hints and tips and tricks that you guys can give me to help solve this issue? Here are some photos to show what everything looks like.
I don't have other examples to look at to tell if the spacing is off because of all the repairs done to the doors and the rear sill.
clearly the right door hangs a bit lower than the left. I loosened everything up and used the floor jack to raise it up as high as I could get it and then tightened everything back down but that's all I can get. I've included photos to let you look and see if I have installed it correctly, the sagging parts not withstanding.
