- Thread starter
- #21
Correct, I did not mix pinions. I'm using a new matched set
The point I was trying to make before is that I switched methods of shimming the pinion due to me having to reduce the shim stack thickness
Yesterday I had the shim on the pinion (between the bearing and the head), and today I've removed that shim and began shimming the bearing race.
The pinion shim (yesterday's method) is solid and .0795 thick. Since everyone recommended to reduce the shim size I switched to the shim stack under the bearing race method.
Does that make sense?
