Real time: my gear pattern
Northeast PA
Having never done this before, check out my gear pattern and see if I have this screwed up.
I'm thinking it might be a bit toward the heel, indicating the pinion is too far away.
I have the factory shim under the pinion measuring .0795
Is there any noticeable difference in the patterns due to my changes in backlash?
To me it appeared to change the heel toe distances.
Ill mess with the shims tomorrow. Thanks for the help!
Ill post more pictures after I do the adjustment.
the first time setting up gears is kind of nerve racking with the cost and time involved and the possible outcome if it's not right. From what you have posted you are doing OK.
get yourself a note pad and record your shim specs and backlash with associated pictures. This way you can see what yu are dong and how it effects the pattern.
.007/.010 less shim and check again...
You are too deep, you do need to back off, As others have suggested take notes, I believe you are not as deep as pin suggests, but deeper than landtank suggests. It may all depends on what shims you have on hand. take your time and take deep breaths. Enjoy.
That 070 shim should have put it very close....instead, you now appear deeper than before. Something is not tightened down....
the 2 top pics are drive...the 2 bottom ones are coast side.
The drive is too hard(well, not that hard) on the toe(inside) and too deep in the root(for sure) of the tooth. Are you sure you have the inner race seated down fully? And did you possibly add up the shim pack wrong?
ZUK
Well, let me back up.
Yesterday's pictures were taken while I had the factory 0795 shim located on the pinion. I removed that shim (or washer) from the stock pinion and put it on my new pinion, then ran the pattern.
Since the majority of the advice was to lower the pinion, tonight I separated the new pinion from the bearing, and removed the factory shim (washer).
I then measured a stack of shims at once (not individually) and put them under the inner bearing race. I'm fairly confident I had it seated fully.
Perhaps my error was trying to measure the shims as a stack, rather than individually and adding them together?
Regardless, in your opinion it appears I need less shims, correct?
I don't believe that he is mixing pinions. These are a new set of 4.88s.
It is very strange that the pattern looks like the pinion is deeper after using a .0095 thinner shim. Something is not right. Either the bearing isn't seated, or there is a piece of dirt in the shim stack or the measured thickness is off.
