My starter wont engage with full battery and no matter what gear. My friend and I banged on the starter, hooked it up to jumpers. The lights dim and radio shuts off. Don't know what else to do... Your input is very much appreciated.
I tried in both park and neutral and the lights dim when I try to start. I had it hooked to a running car with jumpers the hole time.What gear you are in? Manual?
What sounds are going on? Clicking? No clicking? You said lights dim, only while starting? Is the battery fully charged?
If you've been trying to start for the past half hour then you probably discharged the battery.
My multimeter shows 13.3 it has been doing fine. It sat for about 7 days while I upgraded the suspension.
Doesn't the radio shut off anyway when you're cranking? I'm not sure on this though...
Do the lights go out, or just dim?
I pulled the starter and had it tested and it works...Then you likely need to pull it if you've already jumpered it without any results. Baselfish is right.
tested and voltage drops to 12.6Leave the volt meter on the battery and have her try and crank it. If the voltage drops below 11 volts when the key is turned to start you may have a bad cell in the battery.
How many amps does that jumper need to handle, because I tried a wire I had and it almost melted...Remove the small wire plug and jumper from it to the + on the battery, or to the battery connection at the starter.
If it starts, you have a wiring problem at the switch or somewhere. If not, recheck those battery connections.View attachment 1060362
Got a bigger jumper and it worked.It should be fairly low amperage. Like 16 or 14 AWG wire. Speaker wire might be too small. You're throwing a fairly heavy contactor, so it might need a reasonable amount of current. Guessing not more than 10A, but that's a guess.
There used to be a security alarm I removed recently. There were two green wires connected to the ignition that I clipped...Ok then now we are getting somewhere. Is your starting circuit totally OEM or has it been played with at all? The OEM starter switch, where you put the key, on some vehicles has been known to slowly start to fail and in doing so doesn't allow the full current to the solenoid. When this happens you can either replace the switch or you can install a starting relay that then doesn't require the full power to go thru the switch, only enough to power the relay which then sends the full voltage needed to the starter. Here is something a few have done with great results:
https://forum.ih8mud.com/threads/starter-ignition-circuit-thought.211786/
