Real time help...
So what do I do with the wires.... haha
Do you know what alarm you have? Is it the RS3000 alarm that typically was dealer installed or is it aftermarket? Those wires aren't the only part of disabling the starter. If it was then thieves would have an easier time starting cars ;)
I'm guessing this is a "We've all been there..." moment. A moment when you post a problem that you can't possibly figure out and a few guys walk you through it and you realize you just posted your lack of thinking on Mud. Don't worry, we've all been there. Sometimes it just takes another set of eyes or clear brain to help figure it out. :bang:
For the record, when I say "We've all been there..." I mean, "I do this regularly...". :flipoff2:
It was an oooold viper c60 that hadn't worked in ten years. So I made an attempt to remove it completely....
My alarm interrupted the starter circuit with a relay. Make sure that is a good high current capable splice when you remove the relay and the rest of the alarm. If you did a bad crimp, it will be the cause most likely.
Glad you found it!
Glad you found it!
So I just connect the two green wires?....:hmm:
What year is your truck?
You might just have a t-harness in there that you can remove and be done with all the issues. Depending on the year, there will be a connecting harness under the steering column.
If you remove it and connect the two ends back together again, the interception of the ignition kill and other such things is no longer a problem.
The harness on mine looks like this:
And here are the two ends you can put together...
Well it only took us 5.5hrs to pull all the information out of you and ask the right questions hahahhaahahahah
:cheers:
On a side note... my difflock light is on..:(
