Real time help! Transfer Case Re-assembly
Near Boston
I am ready to re-assemble the transfer case. I did the Looka part time kit and front and rear output shaft seals, and bearings. (Thanks Beno!)
? What are you guys using to seal the case back up?
FSM says Threebond, what I removed looked like red silicone?
Also I need to torque the part time hub to 72ft lb, seems that it all wants to turn on me, the only other idea I had was my 3/8 impact gun? Any help here
View attachment 1090607 View attachment 1090609 View attachment 1090610
FSM - red fipg
For sure! I used black on the front diff once and it failed. I've since done both diffs and the t-case in red and have had no issues. It's worth the $ IMO.
Red oem Toyota fipg.
Permatex Ultra Grey or Gear Oil RTV either works great, used many times, zero leakage.
...Also I need to torque the part time hub to 72ft lb, seems that it all wants to turn on me, the only other idea I had was my 3/8 impact gun? Any help here
Don't see how you are going to get 72ft/lb with an impact, a torque wrench would be better.
As has been said red OEM transaxle FIPG.
You need a torque wrench to get to 72ft/lbs. Since the case is out of the truck, you need to find a way to hold the gears. I used a large screwdriver to hold the gears, worked well and no damage to the gears.
