Real time help. Problems starting.
Alabama
So, went to the gym, worked out, tried to start my 40. I got a few revolutions and then, everything stopped before engine started. Tried to turn over again, nothing. Even my guages aren’t moving. Checked my battery connectors, seem fine. Thoughts?
Doublecheck your battery wires. Check cable is tightened down to the terminals.
Disregard. After a quick filing of the connectors and terminals. She fired right up.
That'll do it every time. On a trip to the Maze District of Canyonlands with my youngest son in our '84 FJ60, we were heading towards our campsite at the Dollhouse, and dropped the front wheels off a small sandstone ledge into a hard packed sandy wash. The engine abruptly died, and we were waaaay out in the boondocks. Popped the hood and checked the battery connections right off the bat. Sure enough, the negative cable had popped off the battery post.
This is exactly why I quit going to the gym :cool:
Glad you worked it out!
Yeah this would happen occasionally to me, especially in hot weather. So occasionally it happened that I never really pursued a permanent fix. Yesterday it did it to me. Dang. Ok, loosen connections at starter, wipe everything clean (I “commute” on dirt all the time, very dusty) and tighten back up. Except this time tighten too tight and break the wire mount right off the starter. Might have been cracked anyhow, or at a minimum getting aged. I now have a permanent fix - a new starter lol. But the boring part is this is an SBC so it’s just a $48 Delco-Remy remanu.
