Re-assembling front locker...quick ?
Colorado m'fing Springs!
Which position is the cog go to be locked on the differential. I removed the actuator in the locked position then played around with the actual locking mech. on the differential sliding it back in and out but didnt stop to note original position :idea:
Let me clarify: The locking cog that slides in and out of the differential itself, which position is locked?
All the way in is locked. I don't think you have to "index" the motor with the position of the "cog"; the motor will figure it out.
Yeah once i started playing with more i found out which position would allow the sides to spin opposingly. Then lined up the motor to the bolts holes and it all feel into place. I can know say i know this locker shinanagens in-n-out!
While im at it, are there any differences in the birfs or axles between a rig that came locked vs unlocked? Id like to use my birfs and axles out of my unlocked axle into this one after i found pieces of broken cage and worn axles.
You know its funny this thread popped up, I too pulled my actuator and 3rd memeber, and apparently put it back together wrong. Tonight when I finished with new seals and putting in the Longfields, I went to pull out of the shop and couldn't steer at all. I quickly realized the front diff. was locked even though I was in high range. I was a bit worried at first but I put the truck back on the lift and pulled the acutator out, pushed the little cam thing inside to one side and spun the tire. Voila. Unlocked. So I put the actuator back in. Everything works, except I have one problem. When I lock the front axle, it locks, BUT the little indicator light on the dash continues to blink as if it was not locked. I am confused. I am sure it is something simple, but I don't know what it is.
D
The position switch tells the car if the diff is locked or not locked.
Did you forget to plug back the position switch harness?
Yes, it is plugged in. I even unplugged it and plugged it back in until I heard the definate click. Still nothing.
D
My internet guess; ether the problem is in the switch circuit or the actuator isn't timed correctly, so it's not fully locking. Did you follow the FSM procedure when installing. The actuator gear needs to be correctly timed, engaged with the last rack tooth and the actuator turned to spring preload the shift fork.
Contradicting ideas there :hhmm:
I could not find anything in the FSM pertaining to the actuator install/removal. Where in the FSM is it? Wanna make sure mine is correctly installed.
Somebody should post that up so I don't have to find a way to d/l the FSM. :)
D
Should D/L it, way too handy to be without!:hillbilly:
I don't understand the picture with the battery. Do I use the battery to move the pinion? If so what does it means: Do not supply positive directly?
