What stud/cone washer are you supposed to run? I've been running factory hardware for years without a problem.The RCV flange is designed for large cone washers, as well as bigger studs. The cone washer is sitting to low in the hub, hence why you have no thread left on the stud.
Cheers
Just measured some parts and without taking a mold of the taper, the bore and taper are about 0.020" bigger. Still not big enought to get a 10mm gauge pin through the bore.
Would be super if you could run some larger factory hardware while still utilizing studs and cone washers.
