Rare Reverse Light?
Honolulu, HI
Ok, so this light is stock, according to the owner. I can't find this particular reverse lamp anywhere, and theres no other lamp on the truck, so I thinks its stock.
Now, is this something that I should be hiding away in a safety deposti box until the resto is done?
Right, the 73's I 've had had it.
That's a hell of a back up light too. I love the one on my 73 FJ-40. Provides very good light. If you look closely you will see that it is angled slightly down and everything to provide the best light. Only problem is that it doesn't light up the passenger side area very well, it is a little dark on that side of the vehicle when backing up.
As far as hiding it away, well, there should still be plenty around the world on wrecked cruisers, try SOR, they may carry the whole unit still. I broke my glass lense a couple of years ago while tightening the two screws down, broke it right in the middle, SOR had a brand new one still.
I would check your metal housing carefully, looks like you got some rust. The light itself has a small drian hole on the bottom side to let condensation out, but you may be rusty and or thin on metal on the inside of it. A good welder could probably patch any rust through on the bottom half, it is fair metal on the housing. The chrome trim ring might shine back up pretty good.
Fix it and use, it is a good light. And unless you back right into something or get tailgated, it doesn't seem to ever get in the way.
What kind of backup light did the 74's have on them Poser. I never thought twice about mine, it is a good solid light. I know the earlier models had the recessed back up light in the same spot, and I thought the tailight integrated backup lights came out in the 75 model year 40's.
Mine is a 4/73, so when did they start and stop that tailight.
I always figured it wasn't that rare, maybe I should prize it a little more.
Yes.
They were used for one year on the 1973 40 series only...
Assembly has been discontinued for some time from Toyota.....
They were available not to long ago..........Might try.
I aquired a replacement for my '73 recently. Free from a fellow cruiserhead at the Rising Sun Rally this summer. :D
74's have the later horizontal taillights with the integrated back up light, like the newer models up thru 83
Hrm. The lense is not so good condition. Perhaps I should start poking around. Anyone got a P/N?
Oh, and regarding the doors and tailgate... Anyone got a picture of the door handles? Apparently mine aren't stock, because I can't find any pictures of them online, and the soft top has been replaced, so I'm not sure how the original handles were. :\ And, since the tailgate looks like swiss cheese.... Does anyone make a metal OEM style replacement?
09/73 and later 40 series had the backup light integrated with the new tail lamp assemblies that were introduced and used for the rest of the production run...
Contact Cdan.
Ehsan does in Pakistan....
Sweet. Now all I need is money. Got a p/n? :flipoff2:
Here's a link to a tread with pictures of the OEM soft doors.
https://forum.ih8mud.com/showthread.php?t=64558&highlight=oem+soft+top+doors
I think two or three venders are now making reproduction tailgates. The hardware is the part that harder to find, so if your hardware is usable you just need the tailgate.
John
Was reading through posts at lunch and saw this thread. I didn't like the amount of light my 73 back up light was giving off so I decided to upgrade it a bit. I took apart the housing and took all the "light" hardware out. I had an old PIAA fog light laying around in the garage and decided to use that. My stock light was now just the body and lense. I took the electrical part of the PIAA along with the silver reflection plate and installed those into the stock lighthousing. I did have to trim down the PIAA silver reflection plate a bit. Everything fit in place like it was factory and bolted it back up. Now I get about 10 times more light comming out of my back up light. Works like a charm.
Hah, I'm gonna have to get out my stopwatch. You think he can hook me up with body parts for our Sienna? The poor thing is beat up. :(
