Random starting issues
Just wondering if anyone else has experienced/fixed this issue. About twice a month when I turn the ignition key my truck acts as if the battery is completely dead. I starts to turn over and then cuts out. I pull the key out and try again and it starts just fine. I hope this problem does not happen more frequently and then fail completely. Any ideas?
Hello. I just logged on to research starting issues, myself -before asking questions. But, I noticed your post, right away, and thought I'd better reply.
Well, it sounds like you are having the "beginnings" of what I'm going through, now. A few/several months ago, I had the same experience you describe: get in, attempt to start, acts like battery is nearly dead (click click sound, a little), then re-try to start a few times and it started. Afterward, I checked to batt to make sure it was fine, and it was. Thought/hoped it was a one-time anomaly, but it wasn't. The falter didn't happen every time or day I tried to start it, and after it happened a number of times, I became less concerned since I realized the vehicle would start after multiple attempts. The falter seemed to begin happening with more frequency, then, about a month ago, I went a few weeks where it didn't happen at all.
The falter returned, however, but it was the same -where I was still able to start the vehicle after "X" number of attempts. That was till just a few nights ago when a NEW, related problem arose. I got in the vehicle to go out; here's what happened:
I turned the key and the falter occurred. I turned the key off. I turned the key, and again, the falter occurred, but as I was turning it off (in the split second before I moved the key), it began to catch. I was already in motion to turn the key off, so I did, but I quickly turned it back on, to start, again, and the engine caught, but I felt *something* and then heard *something* and couldn't place it, so I turned the ignition off -and heard and realized my starter was still engaged and turning over the engine with the key in the complete OFF position. I reacted, by turning the ignition back on (the engine started and the starter kept spinning), then back off, hoping this would correct the issue. NO, the engine stopped running, but the starter kept spinning and turning the engine. I repeated ON, OFF a couple more times, with the same result. Then I began to panic with concern I'd burn out my starter, so I quickly ran to grab the multi-tool and a light and disconnected the battery, which ceased the starter.
I was hoping the disconnect of the batt, and a few moments rest, would correct the starter running issue, but it didn't. When I reattached the battery, the starter engaged. It has been these few days and it is still happening. The weather was crap, so I couldn't get out there to begin my investigation. Today, I finally did.
My thought has been there is a short created somewhere -maybe at the terminal/connection point on the starter. I've disconnected the starter wire and the plug and don't see anything obvious. I'm not sure where to look, at this point, hence logging on and beginning a search. I don't expect this post to be much help to you, other than to serve as a forewarning so something similar doesn't happen to you.
One more point -I know there is a lot of talk about starter contact issues. Off the top of my head, I don't recall what they are, but I know I've come across that point quite a bit. I'm sure there is much to be found in all these threads.
When the starter stays engaged that is a sign that the starter contacts and plunger need to be replaced. Search on "starter contacts" and you will find many threads with pictures. Its a relatively cheap repair. Sometimes the ignition switch can cause some issues but that is relatively rare in comparison.
I was having the 'click' issue then mine started to shriek when attempting to start. I decided since the starter was almost 17 years old I'd replace the starter as opposed to rebuilding it. So I replaced it today. It was fairly simple except for breaking loose the 2 mounting bolts. They were ridiculously tight, even using a cheater bar! Truck now starts faster(I thought it was slow at starting and I was right). Tips on changing starter:
Soak the 2 bolts with PB Blaster
Get a friend to help
Get to lower bolt from underneath
Get to upper bolt, wiring plug and cable thru drivers fender(move plastic flap, you'll see)
Lower alternator down between frame and motor
2 mounting bolts are 17mm
Cable but is 12mm, IIRC
Hope this helps!
Bad/old starter contacts and plunger can cause a variety of issues, from weak cranking, no cranking, constant cranking after the start position has been released.
The latter is when the plunger welds itself to the contacts and that's not fun.
The starter contacts and plunger can be rebuilt for about $20 in parts and about an hour or 2 in labor.
Since the OP's starter is now 16 years old, you may want to look into that. There are hundreds of threads on this subject.
Do yourself a favor and install a jumper/test lead on the trigger wire for the solenoid :banana:
The next time it happens, check the voltage on the test lead as you crank.
If the voltage is low or zero, then it's either an ignition switch or neutral safety switch issue.
And if this happens to be the case, you can trigger the same jumper lead as an emergency start so you're not left stranded :cool:
I had a similar issue after a late night of some mudding..(I h8 mud!) Dealt with it for weeks then finally decided to pull my starter, disassembled and cleaned it thoroughly. That problem in now solved. I occasionally now have an issue where the engine wont catch. turns over but just doesn't start.. after trying a couple times it will finally catch. stumbled across this thread searching for my issue. Hope this helps.
Thanks for all the advice guys... I love this site! .. I happen to have another starter that I scavenged off an intact 95 FJ80 I found at the junk yard... that's right... a complete 80 just sitting there.. So I grabbed everything I thought would be useful for about 100$ one being a starter... Is there a thread out there on how to service it... could I clean the spare one and throw it in there..?? I have a really hard time with the search engine on this site....:bang:
Google "fj80 starter contact rebuild". That should hook you up. I think the SLEE website has a good write-up.
