Ramhorn question
Will LH and RH Ramhorns interchange? I need a set for my sbc with marks adapter, mini truck ps and pto so room is tight. does anyone have a picture of this setup? I think I need the drivers side to dump straight down.
should be if you have ones that point straight down, some are pointed back and are side specific.
the other difference is that the DS one will have an angled ring for a gasket to fit into, where the PS will be flat for use with a heat riser, or spacer in my case.. I ended up with two passenger side ones, and spent about 20 minutes with an air grinder getting a bit of an angle so the gasket would seat up good!
Trevor
