Radiator?
Chattanooga, TN
Could someone please tell me what kind of radiator I should replace my OEM one with on my 97 80?
Thanks
Thanks. Nice color on your LC, I might add
OEM is about $370.
CFS for me. Aluminum with copper core. $400. No issues and pleased.
Koyo has worked great for me. I have the A1918 version. I paid about $180 for it new.
I replaced cooling system with Aisin fan clutch, Goodyear hoses, Koyorad radiator, Toyota thermostat and Aisin water pump. It has run very well even at well over 100 degrees in Moab.
Cheapest I see it now is CarID Koyorad® 1918 - Radiator Assembly
Here's a thread about the aluminum version vs copper:
Koyo C1917 or A1918 Radiator?
CFS is a three row all metal the cools very well. I only get about 150,000 +/- out of them. On mine, the upper tank starts to leak. Could of had it boiled and welded but I still would have an old tired radiator. Someone offers a lifetime warranty on the CFS. If you plan on keeping your rig it's worth the little extra cost.
Some might think it sucks to replace the radiator every few years but I the think that's why I haven't had to replace the head gasket (got it with 200,000 mi and PO said he didn't replace it either).
My thinking is the radiator gets buildup even with Toyota Red and distilled water. Plus the fins get damaged from stones and baked on bugs. As it slowly reduces its cooling affect, you all of the sudden fat a leaking head gasket, even though it was getting hotter and hotter over time but not enough for you to notice. My theory is that the radiator should be replaced just like spark plugs wires. Even though it still works, replace it. (Then again my spark plug wires should of been replaced two radiators ago)
I could be full of crap too... it's just my theory.
With 458,000 miles, I would say you're on to something. I've replaced the radiator in all three Toyotas I have now in the first few months of ownership. I have a (likely irrational) fear of overheating. I treat radiators as a maintenance item and agree when you say 100,000-150,000 they should be replaced.
Thank you all for the help and suggestions. I bought a Koyo last night on Amazon.
@DR71 You may know this already but a good tip when installing your radiator is to cut the cardboard box it comes in to protect the (interior) fins. After you have all hoses, belts and bolts installed just remove the cardboard and viola, no fin damage! Don't ask me how I know :meh:
Thanks. Any tips for install are a plus. I'm a s***ty mechanic, but I'm working on that.
The hardest part for me was getting the fan clutch out, then getting the new one back in without messing up the radiator. I did the belts, thermostat, water pump, hoses and temp sensor with Koso guage while I was in there too. All in all, it is a time consuming but not difficult operation. Several good write-ups on here, but you'll figure it out as you go if you don't have a go-by. Get a Scangauge so you can keep an accurate eye on your temps.
