- Thread starter
- #21
Thanks a lot. Everything else is good except the hoses and thermostat, which I will replace. Going to a friend's house with an incredible garage set up (also a mud member), so it looks like I will have help if I get stuck. Going to try to do it all myself. I like your avatar BTW. Squidbillies was written by a guy nearby.The hardest part for me was getting the fan clutch out, then getting the new one back in without messing up the radiator. I did the belts, thermostat, water pump, hoses and temp sensor with Koso guage while I was in there too. All in all, it is a time consuming but not difficult operation. Several good write-ups on here, but you'll figure it out as you go if you don't have a go-by. Get a Scangauge so you can keep an accurate eye on your temps.
