radiator
Austin, TX
Hi folks, new to me LX450 (115K miles) and would like to get your opinion on something. I am planning a trip to Colorado in the next couple of weeks, probably 3000 miles round trip. I know from PPI I should replace the radiator (and belts) because of discoloration but also have a minor oil pump cover seepage (probably should do crank seal?) and honestly do not have time to get into all that before my trip. From the looks of the radiator (see picture - coolant around cap is because I opened it under slight pressure) how risky do you think it is taking a trip like that with this radiator? Maybe just do the radiator and belts and address the leak later although I understand it is easier with the radiator out.
thanks,
Scott in Austin
At 115K, the radiator has had way fewer heat cycles than the majority of them here with failures. Yes, the color looks light, but with low heat cycles, you may be OK. For $375 you can have a new one from Toyota and it comes with a new cap.
I would focus on belts, hoses, thermostat, new radiator cap, quality of coolant, heater valve, PHH, and make sure the cooling system is clean and clear before trying to replace the radiator.
My radiator blew in 2014 with 210K on it and it was preceded by a belt failure that stopped my water pump and caused a sever, sudden temp spike. The cap was clogged up (because the PO mixed red and green) and didn't relieve fast enough so it blew and split it lengthwise of the top cap. That was the start of the overall rebuild and I went in and did a LOT of stuff since the radiator was out and it was going to make stuff easier.
Good Luck and safe travels!
Do the radiator, fan clutch, thermostat, water pump and heater valve. Worry about the oil leaks later if you don't have time. BTW...it's a LX450...don't short yourself ;)
Hi folks, new to me LX350 (115K miles) and would like to get your opinion on something. I am planning a trip to Colorado in the next couple of weeks, probably 3000 miles round trip. I know from PPI I should replace the radiator (and belts) because of discoloration but also have a minor oil pump cover seepage (probably should do crank seal?) and honestly do not have time to get into all that before my trip. From the looks of the radiator (see picture - coolant around cap is because I opened it under slight pressure) how risky do you think it is taking a trip like that with this radiator? Maybe just do the radiator and belts and address the leak later although I understand it is easier with the radiator out.
thanks,
Scott in Austin
Maybe replace the cap and go ahead and take a new radiator with me in case I run into trouble along the way?
When the radiator catastrophically fails will it typically damage anything else?
thanks,
Scott
Corrected....thanks :)!
thanks,
Scott
Much easier to replace it at home.
Could cause the head gasket to go.
There's no way to tell from a pic if the rad's about to go. Cooling capacity is the best indicator, other than visible leaks or damage. I'm not telling you to change it, but if you are worried about it, don't put it off until something bad happens.
I'm in the minority here, but unless there is some sign the thing is failing other than color, I would run with it. Again, that's just me. I just got a new to me cruiser and for the cooling, I flushed the system. Went to replace the hoses, but the first one I replaced looked OK to me so I didn't do the other. I went on a 800 mile trip, no issues.
I hear what others say about easier to do at home, and I totally agree. However, I just don't have the money to replace everything that may fail and would be easier to do at home. Life with a cruiser and a limited budget is tough, a series of compromises, and has some risks.
thanks,
Scott
NO...don't 'take' a new radiator with you. If the original fails...you know it will happen at the worst possible place and time. Put a new radiator in it now. New hoses & belts. Check your fan clutch (very important). Check your PHH.
You can take a means to bypass the heater valve with you. Take a thermostat if you don't want to change it out now.
Basically....install the things that would leave on the side of the road NOW. 'Take' the things you could change out in a parking lot.
Or get AAA premium plan and hope for the best. ;)
Seriously, make time to get your rig road ready (the big stuff) before you go. Take along the things that can be easily changed out (if needed). Don't take anything that is going to require a mechanic and a shop to install/fix.
Edit to add: And for the Love of God don't put a CSF 2517 radiator in it. I can't bear to read one more post about how you should have gone with aluminum and that now your rig is going to run hotter than the surface of the sun. :(
I would replace that one based on age/color, after a point the plastic becomes brittle and IMHO that is a time bomb. The same applies to the heater valve. If still original, the clutch is an Eaton, good clutch, if still performing well, wouldn't worry.
^^^^^ Agree with this 100%.
When the top on mine split it didn't look much different and gave no warning. I need to do my heater valve soon.... as it has now become discolored rather badly and likely is brittle.
I'm not sure that the Eaton fan clutch isn't actually better than an Aisin in some respects. I know I would certainly keep it if in good condition. I would likely do the fluid mod on either.
Great thanks, I know what I gotta' do!
S
There are several active threads about radiators here. One of the options is the TYC 1918. On Amazon for about $125. Seem to be one of the coolest running units and so far they are holding up well in spite of their low price.
Some folks here are on their 4th summer with no problems. I just switched over from a good Koyo 1918, and I am very happy with the TYC running cooler.
is that preventive maintenance with the water pump? just the gasket?
thanks,
Scott
So, are you saying replace the actual water pump? or just the gasket? 115K miles original water pump.
All hoses were done about 7 yrs/25K ago including PHH and look good according to the PPI (Landcruiser specialists Austin).
BTW, won't be taking the rig to CO end of July, need a better baseline and time with it to build confidence :)!
Thanks,
Scott
The 1FZ water pump is one of the most durable/reliable I have ever seen, almost never replace them. Some here think the '80 is delicate, make a hobby out of replacing good, usable parts, but they are very durable, capable of taking a beating,,, really they are! If the stuff has been inspected, given a clean bill of health, drive it!
My water pump has 289k miles, it's the original pump. But if you have the radiator out, I would just replace the pump with an OEM one for the hell of it.
