Radiator Replacements
San Diego, California
The OEM radiator finally s*** the bed today, so I need to get a new one. Has anyone used the CSF 2517? As of right now, that is the one I am looking at getting. I have a 93 80 series with the 1FZ.
I have a CSF works like it should but for the price the TYC one people really seem to speak highly of and say cooling temps are better on the TYC thanks to the thicker core and single row construction, buy a new fan clutch and thermostat if not done recently.
Do you know the part number for the TYC one?
Considering that the OEM radiator lasted 33 years, I would opt for OEM 16400-66040.
Don't forget new mounting hardware and cushions regardless of which radiator you choose.
As you'd be pulling everything apart anyway, a new OEM fan clutch, water pump, thermostat, belts, and hoses would be on my list as well.
Fan clutch: Aisin FCT-004
Water pump: Aisin WPT-023
Thermostat: Aisin THT-015
Alternator belts: 90916-02353
AC belt: 99332-60910
Radiator hose #1: 16571-66030
Radiator hose #2: 16572-66021
Radiator hose #3: 16573-66010
Might as well throw in a new fan shroud with the updated design: 16711-66031
And a new fan to replace the one that has been sucking on 200+ degree air for 33 years: Aisin FNT-004
The oem one was brass though. The new oem specs are just plastic like the cheaper versions available. While, I prefer oem as much as possible. I used a koyorad on mine this summer, as I highly doubt a new plastic one is going to last another 30 years.
80 Series OEM radiators (TRAD) have always had plastic tanks. 1991-1997.
The last OEM radiators that had metal tanks in a USA spec Land Cruiser were the FJ60/62 series. Like Jon said, all plastic tanks after that.
Op
I changed out everything Jon listed above and did Toyota trad rad, and had a black hub clutch laying around that I put in.
Last summer was running 191 and up in high heat with AC on. Would climb on mtn passes. Not sure what brand rad it had. Would see 200 in town at times.
After replacement I see 181 most time, with the highest 193 in stop and go with AC and high temps outside. Climbing passes stays nice and cool now as well.
In my red 80 I have changed all out as well with blue hub clutch rebuilt to 20k. CSF metal radiator, fine in stop and go, but sits probably 10 degrees higher then the oem, and climbs in passes. I will replace it with trad here soon.
Oem trad just does such better job. If it last 10 years good enough, my 94 was 30 years old before it died.
93 94 were plastic tank brass inside, 95 up plastic tank aluminum inside.
Fwiw, the part number I listed (16400-66040) was for the OBD1 FZJ80. It is a direct fit for all USDM FZJ80s, and is what I have in my LX450.
Hey all, I have an update. I ended up getting the TYC 1918 rad and the one they sent me had a few flaws, and I ended up sending it back and getting a replacement of the same rad. But I had a question for you guys. I noticed the bungs for the oil lines in the bottom of the rad had some thread exposed, and I was wondering if it was made to be like that or if there are supposed to be no threads showing. On my OEM rad, there are no threads showing.
Yes, on the TYC1918, the trans cooler/heater line connections are brass with threaded fittings and it's normal to have threads showing. Depending on their orientation, you may need to loosen slightly to point the connections to the DS where the trans lines attach, then retighten.
I'm betting your first TYC1918 had a sizeable dent in the left side mount, amIright? Some goofball at the chinee factory is in the habit of banging it against the test tank when he removes it. It's kinda his signature move to leave his mark on the world...
I installed my dented one and it's been 100% for the past 5 years.
Well, you don’t HAVE to settle for plastic. Ron Davis and Griffin are all-metal. Be sitting down when you hear the price, though. 💰
I have recently done all of this except my differences were:
Blue Clutch Fan instead of Aisin (Can't find link/pn but commonly referred as the best)
Liland Aluminum Radiator PN 1918AA (I chose this because I too did not want the plastic capped OEM. Considered the next-best to the $1k racing radiator and I would say that the build quality is quite good.)
OEM Radiator Cap 16401-54750 (Cheap insurance while doing all this)
Heater Control Valve 87240-60170 (Common failure point, $57 on ebay)
Slee Headlight Harness Upgrade (SLEE - 9005/9006 Headlight Upgrade Harness - New and Improved! - Slee Off Road - https://sleeoffroad.com/products/lig1001v2/) While the front end was apart, why not.
Aisin is the OEM for the fan clutch as well as many other parts.
The Aisin FCT-004 is exactly what you'd get if you purchased Toyota part number 16210-66020.
The only difference is the price.
