Radiator Leak
Monroe, GA
After a trip of less than five miles and back this afternoon, I noticed a coolant leak (4 or 5 fried egg size spots) on the driveway about an hour later. I cranked the truck, and after it ran for less than 10 minutes, I saw coolant starting to bubble out at the seam where the top of the radiator meets the body.
Do I have any options other than replacing the radiator? Suggestions? (Constructive) comments? 2015-05-12 21.12.40.webp 2015-05-12 21.12.14.webp
The chances are great that a patch will not last long....I tried it. A replacement is coming very soon. I just bought a Koyo from Amazon for $153 shipped. All three of mine have new Koyos with no problems so far.
Howdy! On rare occasion the aluminum crimp has failed and you MIGHT find a shop that would try to crank it down. More often the plastic tank has cracked and failed right next to the crimp. Not repairable! Many folks on this forum really prefer the OEM replacement from a dealer. I have had great luck with my Koyo 1918A. I wheel in the desert with it all summer without any problems. I got it in just a few days on Amazon.
With the radiator out , it is a great opportunity to do a lot of other PM work. John
As Inkpot mentioned, the aluminum tabs that are crimped down are starting to loosen up causing the tank seal to leak. A simple/free way to possibly fix is to tap each tab down with a flat blade screwdriver. I would also do it with a cold engine so the tank is not pressurized.
Root cause analysis is in order. Beware that you don't just address the symptoms to only have it happen again. I bought a clean locked LX450 for $1800 because the PO was tired of over heating after replacing several components. Turned out that she was running green coolant after not thoroughly flushing the red. These two coolant types are not compatible and results in crystallization (almost like sand). This clogged the small return hose going into the reservoir bottle which led to over pressurization of the system causing all sorts of problems, such as leaking radiator seams and heater core failure. Ultimately what fixed it was thoroughly cleaning the system, replacing all hoses, and refilling with Toyota red. Luckily the radiator the lady replaced (still under warranty) was replaced for free, but the heater core was toast. My opinion is that you dig deeper.
