rack and pinion steering
up there somewhere
Has anyone ever tried to install rack and pinion steering in a 40? Should be an awesome conversion if possible without a frame redesign.
The more I think of it what difference does a straight axle make? You are only turning the knuckles. Am I missing something here?
When the axle twists going over a bump it will have MASSIVE bump steer with R&P steering. R&P steering is used with independent front suspensions where the pivots of the control arms and the pivots of the steering joints "match" so suspension movement doesn't change the steering angle of the wheels. Now if you have the rack attached to the frame of a LC and twist the suspension the wheels move away from the rack and change the steering angle by massive amounts. R&P tie rods are only 12 - 18" long; how will they reach the steering knuckle when the axle can move 12" vertically on a typical FJ40?
R&P steering is used on FJ Cruisers and the 100 and 200 series Land Cruisers. All of those use independent front suspensions. One of the changes when converting those to solid axle is to change to a steering box and toss the steering rack.
Nick
Like what?
I don't really want to step on anyone's toes or start a pi**ing contest so I'm not going into specifics. It's just my opinion about certain things I have seen that I personally would not have done for one reason or another. I'm sure I'm not the only one who saw something and said why.
I'm just asking why man. What benefits do u see from rack n pinion steering? Are you looking to fix some sort of issue you have with how your cruiser steers?
The answer is no... you can look through the other threads of rack n pinion that come up at least once a year
Yes on mud there has been odd ideas here and there ... and some surprisingly worked
There was once a rack and pinion on solid axle... it was a hack ... a dangerous hack
There are plenty of other things to obsess over on our cruisers ... adding rnp should not be one of them lol
Is it April 1st already?! Fawk, this year is going by fast...
