rack-and -pinion on 40
Discussion in '40- & 55-Series Tech' started by 68 just-parts, Feb 28, 2007.
  1. 68 just-parts
    68 just-parts
    29
    Sep 9, 2006
    Albuquerque New Mexico
    Just brain storming and wanted others thoughts. Would you, or should I say could you mount a rack-and-pinion stiringunit from a IFS to the back of a solid axel and have a viable working system?
  2. Pin_Head
    Pin_Head
    14,464
    2,042
    Feb 6, 2002
    OC, CA
    No doubt it could be done with enough money, talent and time.
  3. AATLAS1X
    AATLAS1X
    7,263
    12
    Jan 24, 2006
    97707
    But why?
    R&P = Cars.
    Gear box = Trucks
  4. numtel
    numtel
    400
    Feb 19, 2005
    Chico, CA
    How are you going to connect your steering shaft to it? It's a rediculous idea basically. If you need more steering than a typical crossover setup can give, look into hydro assist or full hydro.
  5. Mark W
    Mark W
    6,182
    90
    Jan 7, 2005
    The Greatland
    More unsprung weight, more hoses down low to snag, generally not a lot of power, reduced clearance between the oil pan and the axle/steering assembly, less stout than just about every other type of steering system, and one hell of a slip joint on the steering column.
    I've seen it tried a couple of times. Real hacks. Bad idea IMHO.
    Mark...
  6. okie
    okie
    1,456
    1
    Dec 9, 2004
    The West
    haha i actually though tof this and asked a professional about it one time and he said no problem it can be done...
    your gonna have alot of bumpsteer
    basically it would be a horrible ride.
    I would only give it a shot if you had the money to waist and were only gonna drive it on the street... even then i wouldn't
    i actually researched it and people are saying engeneers are trying to fit a rack and pinion system onto semi trucks in the future. who knows
  7. bustanutley
    bustanutley
    2,285
    4
    Apr 10, 2004
    denver
    Solid axle version of rack and pinion = full hydro
    :flipoff2:
  8. Toyo FJ40
    Toyo FJ40
    1,020
    Media:
    8
    Albums:
    1
    Dec 7, 2004
    Eastern PA.
    In a car it mounts to the subframe between the front suspention. I don't know where you would mount it on a 40. With the amount of axel travel you would have to mount it high enough not to get hit by the axle which would be too high to avoid bump steer not to mention the toe in changing with axel movment. I looked at some of the power R/P units sold by Summit and at first look you think it's goint to clean up all the linkages in the front of a 40 but then I think where you going to hang it, I'm probably wrong but I don't think it will work on an axle.
    Kevin
  9. Mark W
    Mark W
    6,182
    90
    Jan 7, 2005
    The Greatland
    With a live axle, you would have to mount it to the axle itself. But it really won't work there either.
    R+P simply is not a realistic approach for an off road rig with a solid front axle.
    Mark...
  10. Fast Eddy
    Fast Eddy
    14,303
    2,016
    Apr 5, 2006
    Morgan Hill, CA
    Yup. No way to connect the column to the R&P if it's mounted on the axle and no way to connect from the R&P to the knuckles if it's mounted to the frame [edit: and still get any articulation].
    The key to R&P steering is that the steering link geometry is very similar to the A-arm geometry, so when the A-arms travel, the steering travels with it without causing bump steer.
  11. tlcruiser66
    tlcruiser66
    710
    2
    Sep 4, 2006
    Western Wa.
  12. miker
    miker
    2,609
    46
    Jan 29, 2003
    Nil Sine Numine
  13. Isotel
    Isotel
    4,058
    Media:
    5
    Albums:
    1
    39
    Sep 29, 2003
    Crawlorado.com
  14. Bennett
    Bennett
    627
    5
    Feb 1, 2002
    Utah
    dont stop with just rack and pinion... go all the way
  15. 68 just-parts
    68 just-parts
    29
    Sep 9, 2006
    that was fun! just thought I would throught out the why? and why not. I am inpressed with the info you guys found on such an od setup.
