Quick head gasket question, how clean?
Azca
If there is a harder way - I will find it...
Surprise AZ.
How clean do you have to have it for a Toyota brand gasket? I am getting to the point of polishing it...
Also, I am noticing some pitting on the top of the block, is this typical?
Clean and smooth are two different things. Clean, it needs to be 100%. Wipe with a white cloth and denatured alcohol and if you can pick up any discoloration, it isn't clean enough.
Smooth. The general rule of thumb is that if you can catch a fingernail on anything or feel your nail drop into something, it's too deep and you should have the surface milled. Especially right around the cylinders and passageways. I can't tell if it's discoloration or pitting on the end of the block in the first pic, but if it's as bad as it looks, I'd have second thoughts about re-assembling it like that. Unfortunately the only solution is full tear down a visit to the machine shop for the block. If in doubt, get a machinist to look at it.
Here are some better photos, I think you are confirming my suspicions, and I am not happy.
No, that does not look good. Especially since that area is a known area for the head gasket to have issues. I assume it had a blown head gasket before you started, over time a slow leak can cause erosion like that. I had the same thing a little bit worse on mine when I pulled it down. I had pulled the whole motor though, I didn't want to risk being in the spot you are in now.
No actually no sign of a leak or failure. I was redoing the head due to significant oil consumption, about a quart every 750 miles now. Also had several oil leaks, one at the rear oil pan arch. As a result I though I may as well pull the motor.
Well, if you've got the motor out, might as well pull the pistons/crank/bearings out and take it over to a machine shop to have it lightly milled. Doesn't cost much and you'll feel better. :)
With high oil consumption, you are doing rings too right? Fresh hone? New Bearings?
No, I know it was getting by the valve seals and the machinist confirmed that for me on Friday. If I am pulling the crank and pistons I guess I will need to do the rings at a minimum with a hone. Bearings, I assume, should also be done. I would assume I would not need to do rods or pistons right??? Perhaps just the bushings...
For a minimum bottom end, assuming everything is basically already good and you don't touch the crank or main bearing journals you can replace with identical OEM bearings using the numbers on the block, new rings (hastings are nice, or you can go OEM of course) and a fresh hone on the cylinder walls. If you want to use aftermarket bearings, you should get a line bore on the main bearing journals and the crank polished and matched for tolerances. I'm sure it's cheaper to use OEM bearings than do all that.
The machine shop should be able to do the hone for you while they have the block, should be less than $200 to do a clean up milling pass and a hone. Re using the pistons is fine, as long as they are in good shape of course, since you weren't having problems they should be fine.
I'll be the voice of dissent. I think you're overthinking it for a naturally aspirated motor - if the block is flat and the head is flat, the OEM gasket (viton over whatever compliant material they use - MLS?) will probably seal just fine.
If you really don't want to mill the block, run a skimcoat of something (jbweld, some people recommend) over the surface and then use a flat (long) sanding block to prep.
I was kind of thinking the same thing, but didn't want to say it and look even dumber than I am, but that looks kind on the borderline for me. On the other hand, the motor appears to be out of the truck already, so why not get it touched up. Peace of mind for myself.
Hone it with a 220 grit diamond flattening plate. As long as you do it evenly and check for flatness, then it should be OK. They cut fast, so count the strokes so you can take the same amount off all over. You would want to remove the head indexing rings so you can polish the entire surface.
