Quick Carb Question
Savannah, GA Area
i have a quick carb question. i been trying to figure out how to solve my idling prob. can't get it below 1000 rpm. so my question, can the float level throw the idle off this much? the fuel level is a little more than half way in the sight glass. thanks
Pin_Head said:
No on the float level. I assume you mean that it stalls below 1K. There is probably something wrong with your idle fuel circuit: fuel cut off solenoid not opening, plugged passage or outlet port.
What he said. Below 1000 rpm, you should be able to get the truck to run off the idle circuit exclusively. When working properly, you won't be able to see any gas flowing out of the carb venturi into the engine. Not even a dribble.
Other causes for failure to hold a low idle would be a vacuum leak, burned, sticking or misadjusted valve, bad ignition timing and or dwell. Keep in mind the carb is often the victim, not the culprit.
rcb said:
sorry. the engine stalls when i try to lower the idle
Which begs the question, can you see gas dribbling down inside the carb at that speed?
