Questions on 80 Build
New York & California
Website
www.rbfilms.com
After getting some help in this forum, I have decided to sell my 100 Series and build my 80 Series.
Minimum Build
* Front Bumper – ARB Deluxe or Slee Short Bus.
* Warn 9.5 Winch
* Rear Bumper – ARB or Slee w/ Tire Carrier and Gas Can.
* Rock Sliders
* ARB Air Lockers for Front & Rear
* CDL Switch for Center Differential
* Lift Kit – Heavy Springs with Lift Height TBD either 2.5" or 4". * Larger Tires – 33” or 35”
* Roof Rack
* Additional Lighting
* On-Board Air for Tires
* Speedo Calibrator
* Upgraded Alternator with 160 amps or better output – (Ohio Generator can rewind a stock 80 Series Alternator for 160 amps output)
* Upgrade wiring in parallel from alternator to battery as required by Alternator upgrade.
* Dual battery setup or at the very least an Optima or Odyssey Battery.
* CB / Ham Radio Antenna, Scanner Antenna, Cell Phone Antenna.
* 500 Watt Radio Class A/B Ham Radio Amp for 2 to 30 Meter
* Direct feed from batter for Radio and 500 Watt Amp
I searched the forum and found bits and pieces of information, but did not find exactly what I was looking for. Maybe I am not using the correct key words.
With that said, I am hoping to get some help with this 80 Series build from members of the forum. I have a few questions:
1 - What is the best lift / tire combo for both good on / off road performance. A 2.5" Lift with 33" or a 4" lift with 33' or 35" tires? This is my daily driver and I do drive some long distances, so I want to maintain decent street manners and ride quality.
2 - I have read that F.O.R. uses progressive springs for their kits and the reviews seem good. Does anyone know about this company and their products? I cannot find them on the web.
3 - Slee Short Bus Bumper verses ARB Front Bumper as well as the rear bumpers from Slee and ARB. My concern about the Slee Short Bus Bumper would be related to Animal Strikes, which is my primary concern, however,the Slee is lighter and puts less weight on the front end.
4 - I like the Slee Bumpers for better approach / departure angle. I have read here in the forum that the Slee bumpers are stronger and more durable as well....especially the Slee rear bumper which does not have as many "pieces" as the ARB. Has anyone heard of any rattles and noises when using either of these bumpers?
5 - Best On-Board Air solution. I do not want to be spending a lot of time airing-up tires. Sounds like C02 may be the best solution, but I want something small and compact that will mount in an out of the way location yest still be accessible so I can easily access the tank for recharging. Unless there is a 12 Volt solution that is almost as fast as CO2...is there?
That's it. Any help from Forum members is appreciated.
When you have the axles apart, you might as well regear for heavy loads and 33's (4.56), or 4.88's (35's).
I woul base how much you will be off-road to choose the tire size. A LOT has to be done to clear 35's properly and carry a lot of weight.
I have heard bad things about the ARB rear bumper, it cuts down on the clearance. Slee, Hanna, 4x4labs are all good.
I don't think you need the higher output alt. I am running lots of toys with Dual batts and the standard alt.
You didn't mention where you live and that make a difference. Stock gears will work ok with 35's at sea level, but can be a real dog on mtn passes.
Also, what type of wheeling do you plan on doing? Moderate off road and AT's like the BFG AT KO work well even in the mountains. If you want a more aggressive tire, then some choose Mud Terrains like Toyo MT's or Coopers. There is an entire FAQ section on Tires that might help you.
I have the ARB front bumper and it has saved me in an accident. I also have the Slee rear bumper and am very happy with it.
Best on board solution is a personal preference thing. The CO2 system is small and portable and one 10 lb tank can fill a lot of tires and costs me $9 to fill up once a season, I can take it out of the truck if I need to use it elsewhere. The onboard system systems are good too, but more expensive. I am happy with the CO2, nakman just swapped his out for an cool onboard air system. He can run air tools without worrying about running out of air.
FOR is a reputable vendor, NAY is using his springs. I have no personal information about them.
Read the FAQ item in the modifications section on OME lifts. It will let you know some of the issues involved for any lift.
Unfortunately my truck is in pieces or you could have taken it for a ride.
I have a hodge podge lift in mine. IMO, there is some great stuff but it's not all in one place.
I have:
Slee's 4" springs and front panhard DIY joint
OME L shocks
MAF's rear panhard drop bracket
My caster plate
2" drop blocks for front sway bar
Slee drop bracket for rear sway bar
2" drop blocks for rear bumpstops
FJ62 bumpstops for front axle, DS with 1" spacer
MAF SS brake lines, only ones available at time of purchase.
I'm very loaded and very pleased. Never a rubbing issue with 35s and I'm geared with 4.88s.
Good Idea...!!! Thank you..:)
Thank you. I have heard some negative comments on the ARB rear Bumper as well.
Slee also said that the stock alternator should handle my needs.....but I am somewhat concerned. I pull an easy 40 amps plus when I key the mic on my radio.
I live on both costs...travel back and forth between West Coast (SoCal) and East Coast (Northeast). I think this will primarily be my West Coast rig....but it could end up at my NY home eventually.
My off road riding will be moderate. I doubt I will tackle any Rubicon / Moab type trails with this build, at least being new to all this. I would say that I would not attempt anything more than a 7 out of a 10 with respect to Trail difficulty rating.
My main concern about on-board air is the time it takes to fill the tires.
Slee and Cruiser Solutions both seem to like the Toyos' you mentioned.
How do I find FOR...does anyone have a website address for them?
Hi,
Yes, that would have been a great idea. I saw your truck, it is setup for pretty hardcore off road travel....:)
What I would hate to do is install a 2.5" EMU Lift with 33" tires and find out I really want a 4" lift with 35" tires down the road .... and have to do it all over again. For my application, I am probably building this one out more than I need to. The only thing I am not adding at this time is a snorkel.
If I did go with the 2.5" EMU kit and wanted something more, I would probably build another truck for my other home on the East Coast. This one is going to live on the West Coast.
I have:
OME L shocks
My caster plate
Another question. I want to change the roof rack but the only one that installs using the current mounting holes is the ARB.
Most builders do not seem to like this roof rack as it is too heavy and does not hold as much weight as a the other styles out there which mount to the edges of the roof.
I do not like the idea of having the holes plugged with a bolt and silicone. This is not a clean look and I would find this unacceptable. Short of having the roof fixed and painted at a body shop, is there any other solution?
Hi,
I started with the 2.5" medium kit, as I added pumpers and other toys I upped my springs and now am running J's with 35's. The nice thing about OME is it is easy to swap springs and change the lift and you can get 50-75% of the money you spent on the springs selling them to other mudders. I liked it because it allowed me to build the truck slowley.
If you jump to the higher lifts right away then you have to worry about larger castor deltas, pinion angle problems on the drive shafts and end up ficxing problems that won't be there after you complete the rest of the build (add weight) of your truck.
I did also swap to L shocks when I got the 35's and went to J Springs.
If you are planning on doing the build all at once, then you should go for what you want.
Mine is a daily driver and I am happy with the lift, tires and setup. It gives me great offroad ability and no issues driving on road. You can see my slow build up by clicking the ROTW link in my signature line.
How much talking are you going to be doing on HF? Most people with mobile HF units get by with way less power-like 10% of what you are suggesting. Can your antenna system handle 500w? I'd like to hear what you plan to use in this application.
I am assuming much of that will be at night when you are not driving, but maybe sitting around at a camp site.
500watts is a lot of power and will draw down a battery fast, at least make sure you have back up battery to start your truck!
Yes, I am doing the build all at once. What about Bilstien Shcoks verses the the shocks the EMU and Slee kits come with? Will that improve things at all?
I am going to check out you build as well..:)
Compared to -0- know how in building / driving off road vehicles ... electronics and Two Way Radio is an area where I have some knowledge and experience...:)
The amp was somewhat unique. There were twenty (2) of these made and I purchased 9 of them. PEP Power Output of the Amp is 500 Watts. Dead Key is 125 Watts with a perfect 4 to 1 Swing on 11 Meters AM and proper filtering along with Class A/B Operation.
I am driving the Amp with a perfectly tuned Magnum S9 with 12 watts Dead Key and 48 watts PEP...again with 4 to 1 Swing on Audio Modulation and a DP-56 Mic and a tuned Mic Pre-Amp on the Radio to provide 100% Modulation without overdrive or distortion.
The power does not seem excessive to me. It is the "Sweet Spot" as far as the point of diminishing returns. I would have to Double the power or better get an additional 25% range. At that point, I would have to customize the vehicle's electrical system to handle the load.
I am running a Van Ordt Powerstick - 200 Channel Antenna which are no longer available. They are great antennas I buy them on the spot whenever I am lucky enough to find one in the dusty back corners of CB Shops. Yes, it will Easily handle the power and quite a bit more as will the Predator 10K Competition Antenna I fun on my 100 Series roof with a Mag Mount.
I will also be running a Dual Battery setup isolated and I will only use the Amp in an emergency when driving or camping. Maybe occasionally on the road as well to step on an obnoxious trucker now and again...:) Otherwise, I will run the 48 Watts out of the radio which honestly has never failed me yet when it comes to being heard. Mostly this is due to super fine tuning of my radio gear....I get out big-time on my radio systems.
I am installing a similar setup on my GF's new 2008 Jeep Rubicon 2 Door when it comes in.
I will eventually replace that with a Kenwood 480 Ham Radio and a proper Ham Antenna.
I still think I need to upgrade my Alternator. Ohio Generator can rebuild a stock 80 Series Alternator to output 160 amps.
My $0.02 on the Short Bus bumper is that it does not protect the headlighs/corner lights, and more importantly, it does not protect the radiator in the event of a rollover or hard hit. The difference between being able to limp home or being stuck in the middle of nowhere is huge.
Not to be rude, but that sounds like a ton of money and space wasted on 11M AM. So you get out, who are you going to talk to? Their little 4 watts isn't going to reach back to you.
I wouldn't worry about the amperage draw. Lots of folks are running winches on 80s with only a single battery. Some of the cheap winches can draw up to 475 amps during a hard pull. That is why I run a Warn as it is more efficient, I think mine maxes out at under 300 amps. But a momentary mic key is not going to draw as hard or as long as a winch pull. Personally, I run dual 1000 amp batteries with a 12voltguy.com solenoid. it works well for what I do and they are quality pieces. I really like that I can use the toggle to join the batteries for a self jump. Most of the time I leave them isolated with all of my accessories on the main battery. Then if it dies I can do a self jump with a fully charged fresh battery.
I would worry about rewinding a stock alternator to produce that many amps. Stock Toyota alternators are pretty good at what they do. They are not like a Chevy that is known for failure. However, it my belief that Toyota alternators are reliable because they overbuild the cooling. When you increase the amperage how do you plan on dealing with cooling the alternator? I know heat is what kills them in Chevys. Just something to think about. If you really want redunacy add a second alternator to charge your second battery.
Boy, I agree with Eric. All of that power and trouble for CB seems like a waste, when you can accomplish way more with just a basic Ham radio, not to mention an HF radio operating 10-20 meters. Still, if it makes you happy then do it!. We have a guy in our local group who really loves his radios, and he tried boosting his CB with a huge linear amp. His signal went out just fine, but he had no more effective range because all of the rest of us had 4 watt units!
Since then we've all gotten licensed, and run Ham radios with up to 100 miles truck to truck on Simplex at 25-60 watts. That kind of puts your power needs in perspective. Maybe I am missing what you are trying to accomplish?
I do see the rationale for running HF in your off-roader. Then you really have the range to reach out of a remote area and call for help. You don't need any 500 watts, though, which would simplify your planning considerably.
If you are not doing Rubicon or Moab just stick with simple. OME heavies and 1" spacers in the front and 33's. No driveshaft mods, simple caster correction and you don't have to regear. It is a problem free set up IMO.
Moab is fine with OME and 33's. I have run it that way and both daughters did this year with no issues. Hells. Fins, Goldbar, E Hill, Porc Rim, metal masher, Poision Spider even Cliffhanger, can be done with that setup.
Don't know about the Rubicon
I will avoid all the radio talk.:eek:
For a daily driver I feel the 33's are about the max if you regularly have passangers. I guide clients out of my rig with OME med and 285/75/16's. I have noticed that some older or vertically challenged client have a hard time getting in and out. If this were my hunt/fish only truck with no worries about clients and kids I would run 35's with a gear change.
As to the bumpers: Definitely ARB on the front to deal with deer and elk. I like the look of the short bus much better but my biggest risk is hitting deer and elk. The rear is an easy question. Slee with a 2" hitch receptical.
The roof rack is a tougher question. The factory rack sucks. I pulled and plugged mine. I have not spent any time researching but my ideal is a con-ferr type rack for load carrying capacity.
Lighting improvements should be started with a harness upgrade. I really like the IPF lighting solutions but there are many to choose from. Don't forget to upgrade or add a good backup light. When mounted high it comes in handy when working off the tailgate. Also, save some draw and install george's led's on the interior.
I didn't get 2.5" from my medium springs. So with your additions I would go strait to heavies. You should also replace your old spring spacers with fresh new ones. You may also need addl spacers depending on weight distribution.
Thats all I got.
:cheers:
The ARB rack is heavy but it is a very good rack that can handle about anything you might want to put up there, my only regret is that the railings are not removable.
Anyway I think you are confused about the mounting holes, the ARB mounts to the rain gutters like all the other serious racks out there, I'm pretty sure you can mount it high enough to clear the factory rack avoiding the need to remove it and plug the holes.
