Questions: Knuckles...
jackbrad
15 Year 10 Year
Charlotte, NC
Website
www.mattison-consulting.com
I hate knuckles.... They are to difficult and messy. I know I am just complaining.
I am almost ready to surrender to the knuckles.
How many of you out there have rebuild you own knuckles?
How long did it take?
Did you use the Steering Knuckle Centering guage?
If you did or did not do you think it mattered?
How many times did you have to take them apart to get the preload right?
Give me your comments..
Jack
Shouldn't take you more than a couple days to rebuild your knuckles, depends on how extensive a rebuild you do i.e. por15 the knuckles etc. When you disassemble...keep note of what shims went were, and you shouldn't need a centering guage. You should be able to get the proper preload w/ the right torque as well.
Once you've done a few sets its not so bad. A parts washer helps speed things up, as well as using small cup wire brushes on a die grinder to clean off the old gaskets.
You only need to use the centering guage when changing the knuckles to ones from a different housing. Keep track of where the shims came from and put them back and you'll be fine.
X2 on the parts washer! If it's your first time it can take awhile, took me a couple of months! (I was doing a lot of other things like powder coating all the front end parts and total drum brake rebuild).
Did not use centering gauge, just kept track of the shims.
Good Luck!
Kinda of related. I am going to us knuckles from a fj62 axle to convert to disks. If I were to order a rebuild kit would I get one for the 62 since I am going to use those knuckles? Will I use the same number of shims or will it change because I am still using the 40 housing? Sorry for the hijack.
Get the FJ62 rebuild kit.
Because you're mating a "foreign" knuckle (as in, one that didn't come with your truck) on your housing, you'll need to center the knuckle on the housing. In other words, you'll need the tool, and you may have to add, subtract or re-arrange the shims.
I've always rebuilt my own...yeah, it's a messy deal. I use lots of newspapers (instead of shop rags) for the bulk of the gunk (cheaper); rubber spatulas are your friends! I hooked my finger once on the inside of a knuckle after I grenaded a birfield, and at a minimum wear heavy rubber gloves anymore.
One thing that always bothers me is having to trust that the PO was as careful with the shims as he should have been. Looking at some of the other PO "maintenance" on my '75 makes me wonder...I'll be using the SST and a fish scale for my next go 'round.
Just be patient, have a good supply of rags/cleaner/tunes at your disposal and have fun with it. Nothing like the look of a freshly redone knuckle :)
And again.
There are guys on this board that will loan you the tool for a deposit and shipping. I was lucky enough to find one here locally, and you may be as well.
It is not a difficult thing to do. If you don't have a parts washer, get a 5 gal plastic bucket and some cheap paint brushes, fill it with Kerosene or paint thinner and get busy. Like Bailey said, a cup wire brush comes in handy. Work your local Cruiserworld and get a buddy to help. This is a very common regular maintainence proceedure.
You can do it.
GL
Ed
I'm curiouse....
I've done three conversions without the SST. Each time I distributed the shims in the kit evenly (one thick and one thin on top and the same on the bottom). The preeload is always right on, and the knuckles dont leak.
Every knuckle I've ever disassembled in a wrecking yard has been the same.
So my question is for the people using the SST.... What are the shim arangements you are most often finding.
My personal feeling is you guys are spending a hell of a lot of time to make sure it is dead on, when the setup is actually much more forgiving......
PMK
We just did a 76 last weekend and torqued the top and bottom with 1 thick and 1 thin on top and bottom and couldn't get over 2lbs of resistance. took the thin shims out and got between 7-8. Didn't know anything else to do so we left it there. P.O. had 2 on top and one on bottom . Never seen that. The book said to take equal #'s of shims out (or add). Hope all will be well.
Later,
i havent used the tool ever.. I just upgraded to the larger pattern knuckles.
it took me 2 nights after work.. I ended up with 2 shims on top, and one on bottom.. im using hysteer arms so the heights on the bearings are going to change anyway.. i just use common sence on how to keep in centerd, and used my micrometer.. i also cut up the backing plate..
I rebuilt my knuckles in 6 hours w/o a guage.
I used the same number of shims that were on the knuckles from the factory. ( I didn't upgrade)
I had to do the drivers side twice to get the desired preload.
few tips:
toliet paper is great to "wipe the knuckles clean"
paper/cardboard boxes will keep your driveway from getting messy
check out post #63
https://forum.ih8mud.com/showthread.php?t=45844&page=2&highlight=pair+fjs
have fun
YOU CAN DO IT!!!
I have rebuilt the knuckles on everything from a 40 to an 80. I have never used the SST, but I do make sure I match the shims that come out. So far I have not had any problems with any of the rebuilds I have done. Parts washer is a great idea, it is a real messy job. I have always installed new bearings so a bearing packer made the job quite a bit faster. I would give yourself at least 4 hours per side, longer if there is a lot of clean up and painting to be done.
Scott
Rebuilding the knuckle is one thing, but are you saying that you've never used the SST when swapping knuckles onto a different axle housing? :eek:
We may be talking apples and oranges.
hey ISOTEL ,i too am sitting on a set of large pattern knuckles .did you use everything in the swap ,knuckle spindle ,hub ,and what caliper ? or did ya just change the knuckle and reuse your small patern .spindle and hub and caliper .
if ya know what i mean
pbgbottle: use the large patern spindle, it fits larger wheel bearings that are probly better.
hth, carl
ps the latter 4runner (93&up?) use 4 large pitons in the caliper as oposed to 2 small & 2 largelike the fj60/62 and older v6 4runner.
definitly use the vented rotor!
also check the FAQ here allthis is covered thjere
