Questions: Knuckles...
pbgbottle said:
.....i too am sitting on a set of large pattern knuckles .did you use everything in the swap ,knuckle spindle ,hub ,and what caliper ? or did ya just change the knuckle and reuse your small patern .spindle and hub and caliper .
Disc brake spindles are all the same.
Hubs and rotors will work from any 40/55/60 series Land Cruiser as long as you use the rotor that came with the hub, since the pre 1980 rotors and hubs are different than the 1980 and later hub and rotor.
Mini truck hubs are the same as the later style Land Cruiser and you can install the vented rotor on them. If you have mini truck calipers however, you must change calipers to use the vented Land Cruiser rotor, or, stick with the solid, non-vented disc. Calipers will mount on all disc knuckles the same.
Calipers-
In 1988 Toyota introduced the V6 in the mini truck and decided that a caliper with all 40mm pistons and vented rotors would be a good upgrade over the two different sized pistons. These can be installed on a 40/60 series and is a good upgrade. The caliper may need to be ground on just a bit, depending on the wheel you are using, and the dust shield will need to be cut open a bit more to make room for the larger caliper.
:beer:
fng55 said:
pbgbottle: use the large patern spindle, it fits larger wheel bearings that are probly better.
hth, carl
Huh?
If it is a disc brake front axle, they all use the same wheel bearings and seal....there are no larger or smaller....unless you are talking about drum junk....
so if i swap my knuckle to the large pattern .and get a later vented rotor for the mini hub .can i still use my calipers i have from the 78 ,40 disc brake set up .are the spindles the same they look different . . or would the easiest thing be to change everything over to the mini stuff .and just change to a vented rotor i think i am confusing myself .
so I was under the impression that when swapping minitruck axle parts (knuckles, calipers, etc, from the dust shield out) that all you need to do is swap over the shims directly from the minitruck to the landcruiser bare axel exactly as they were placed on the minitruck axle?? Is this correct or do you have to go throught the process of using a special measuring tool to make sure the shims are correct. I would think it would not matter as you are swapping the whole knuckle from the minitruck over to the LC axle? I am about to do this swap and wanted to know this for sure before I start, thanks, Noah
Calipers-
:beer:[/QUOTE]
Poser, I used vented rotors and T100 calipers on my fj40 when doing this but found out later that I had to have custom rims made to fit the calipers and keep them from rubbing. Stops great though! Was wondering, I am building a 55 now and if I do the above per your directions, will stock landcruiser wheels work for me? I would like to keep it close to original looking as possible. thanks
Noah
1973Guppie said:
Calipers-
:beer:
Noah[/QUOTE]
As long as you use the welded steel wheel that was used when Toyota went to disc brakes instead of the drum brake wheel that is riveted together, you should be fine.
pbgbottle said:
i have a complete mini truck front end hub to hub and my rig has a
78 front disc brake front end . so i do have all the pieces exept the vented rotors .
What is wrong with the hub and rotor assemblies on the 1978 front axle? Are the rotors junk? They are compatible with the later knuckle/spindle.
If you are set on getting new rotors, purchase rotors for a 1984 60 series and install them on the mini hub.
:beer:
thanks POSER that was the info i needed .all my junk is in good condition .i will just swap knuckles .i am wanting to go with 4x4 labs high steer :cheers: all clear now .
:beer:
Noah
As long as you use the welded steel wheel that was used when Toyota went to disc brakes instead of the drum brake wheel that is riveted together, you should be fine.[/QUOTE]
S&*t! I have the original drum brakes style. Well, might have to find some disc brake style rims here eventually. Thanks!!
Noah
Steve,
I hope that you're wearing a respirator when you are using lacquer thinner or :doh: .
