Questions about jacks, jackstands, etc...
RIVERSIDE CA
What's the preferred way of working on these trucks? They're tall and heavy and I'm curious what jack and jackstand setups you guys are using to safely remove wheels and tires, and work under the vehicle at home.
I only remove the tires that I have to, and put jack stands on the axle as close to the outside as I can. In extreme cases I have put all 4 corners on jackstands via the axles but this is not a great idea. I have some taller jackstands that I place on the frame rails too if needed.
Any time I'm going to be under the truck, I get in it and shake it around, jump on it etc. to make sure there's no chance for something to slip and settle when I'm under it. Common sense stuff really.
Get a decent 6 ton...I wouldn't trust my life with those cheap harbor freight 3 tons.
I should have taken a picture yesterday, I had 4 heavy duty Sears Craftsman jack stands under the axle housing at each corner. Very solid, and I had all the wheels off doing a 5 tire rotation. For extra security you can always place your jack somewhere close to where your working just in case. I have no issue working under the vehicle using this method. Now if I'm really going to be prying on something, i.e. the suspension, I'll lift only the end I'll be working on at that time.
HTH.
I use the 12 tons on my frame often
Anyone distrust flat-top stands in earthquake country?
The notched top stands work perfectly under the solid axle.
For servicing one tire/wheel the factory jack and our Jack Adapter is a very stable and safe. As others have said always use a back up with any type of jack for safety. Slide the tire you removed under the axle will give you the back you need to work safely.
80 series shown also available for all Toyota factory jacks. On the front of an 80 series the adapter locks into place on the front axle making it extremely difficult to move and very secure.
Two 12 tons under the frame & 6tons under the axle when I was installing a new control arm all new bushings and wit's End landtank caster plates
