I don’t have these, I got a set from 69LC a few years ago and very happy with those.
... What’s the best solution for sealant around them once installed?
If your tube doors are Metal Tech you are going to have to change out the striker plates as the latches are reversed. That takes longer than the change.
I think, MC Designs is 69LC. I know there's a big thread on these. Maybe a search is in order
We notched the endcap and sprayed the doors with Rhino. Haven't had an issue but they laid on the liner thick there.Thanks for the tip on the latch.
Did you have a problem w/ the upper hinge on the MT tube doors? I'm going to have to notch that hinge b/c it hits the tube.
I do like the product - but the hinges would be MUCH easier to install if a little thinner metal. The factory bolts barely "grab" to get started b/c of the combo of the thickness and they don't fit thru the opening very well. Especially on the upper/outer bolt of the top hinge it's really tricky - longer bolts not really an option here either as the space is very tight. There is also a very small gap to try and squeeze seam sealer around the front of the hinge between the body lip. A tiny bit thinner would help and not compromise the strength - they are way beefier then need be as-is!
I thought I would chime in on this one too. @69LC has a great product. Here is a solution I created for some members regarding the seal. I made two versions. The first version will fit your unmodified hinges, the second version requires cutting them back as shown in the picture below for what I think would be an even cleaner look.Thanks for the tip on the latch.
I haven’t changed the hinge design since I started producing them. It’s always small batches on the same fixtures.
