Q-jet cfm ?
Portola C.A.
I'm currently running an edelbrock 4bbl carb on a stock chevy 350, and after screwing with the off road springs and needles and every other adj. known to man, the only conclusion between myself and friends is that it is the worst carb you could ever run off-road. I'm sure some will disagree and that's fine, I'f you got it to work kudos to you and I give up!!! I was looking at the Jet Q-jet in the summitt race catalog and all they have are 750 cfm. I was not sure if this was the stock cfm. for Q-jets?? Also, is anyone running the holley truck avenger series, If so how's it working for you?? Thanks for any response, this is by far the best place to get info to keep the land cruiser community on the road.
I know what you mean about the Edelbrock carbs. I'm too running a Edelbrock 650 (jetted down to a 500cfm), Edelbrock intake and still not quite dialed in on the Ford 302.
Heard great things about the Holly and SBC350.
A friend of ours runs the Edelbrock with the offroad needle kit (on a Blazer) with good success. The trick seems to be fuel pressure - he's got it set with a regulator at 3-4psi for trails.
did you try a search ? the holley truck avenger has been talked about a few times.
and i was always told the quadrajet was around 780 cfm. but they have really small primary's for fuel economy until you stomp on it. search it too and you will find tons of info. they are a great carb for off road applications but i am a holley guy, but going EFI.
I was told by the local old-school carburetor guy that Q-jets can be either 600 or 850 cfm, depending on what is came out of. The smaller are supposed to be more common. Take this for what it's worth.
The Ebrok has a huge fuel float bow that floods the engine on any off camber situation or rough road. They make a spring kit and others suggest fuel pressure adjustment. All in all a pain in the but to mess with. I have an almost new Ebrok for sale...
I went back to a Rochester. It has a very small fuel bowl and works perfect off camber.
Good luck
JB
I have had a Q'jet for years now..........they need a fuel pressure regulator, for going downhill, they tend to flood out, I have a Cagle, they are around but hard to find, they are vacuum operated so at idle, pressure is about 2-3# then at open throttle it puts max fuel pump pressure, also I had a problem with fuel starvation when climbing at about 40-45 degrees, the primaries are located in the front of the bowl, so it runs out of fuel for a second, I turned the carb around and all works perfectly. I can give you more info if you like.
Frank.......... e-mail crzr74@hotmail.com
Qjet-cfm?
Here is a pic explaining Qjet cfm's.
Thanks guys, I think I'm going to go ahead and buy the Q-jet because it is a little cheaper than the holley. I also went ice fishing this morning in a friends 40 with the Q-jet and it just purred like a kitten, hopefully I'll get the same results. Thanks again Jason
