I was going resurrect an old thread, but most discussions on good bulbs for OEM housings are quite old, so here you go, a new thread on reverse bulbs.
I have been running the common 7w Cree for about 10years in my 80's, but recently put some different bulbs to the test. I wanted to find a good bulb to sell on my site along with confirming there was something better than what I have been using for so long.
Here are the new bulbs - 21W LED Reverse Light 1156 (1)
I tried three bulbs, the typical 1156 Sylvania, the 7w Cree, and then the new type ( 21W spec) I chose to carry. I haven't tested either LED bulb to see if the wattage is actually accurate as I was more interested in just finding something brighter.
Here are the pictures from the testing.
This is the standard Sylvania bulb. Many people test while the vehicle is off, but I noticed this bulb was quite a bit dimmer when the truck was off, so all these pictures are with it running.
Here is the 7W Cree I have used for years. Its is actually brighter than the Sylvania, especially at night, but during the day its a bit harder to tell. The big difference is the off angle brightness. The Cree is brighter straight on, but not as much from the side. The Sylvania fills the housing much better.
Here is with the new LED. To me, its the best by quite a bit. I like how its simply brighter than the 7W Cree, but I also appreciate the additional led's that fill the housing better.
Finally, here is a shot of both reverse lights on. The left housing has the new LED bulb and the right housing has the old Cree. I decided to stick with the new. I simply like the brighter output directly behind the truck, plus I see an advantage with how it fills the housing better. The off angle illumination is a bonus in my mind.
I might do some at night testing, but I decided to keep the new bulbs installed as I liked them quite a bit more than the old ones.
I also have similar tail/brake light bulbs on the way so I will test those too.
