pumpin up brakes
City that rhymes with fun
ok guys so i got the new cylinders on and what i think set up correctly little bit of drag. but now i gotta pump up my brakes to get it too stop. the first push goes right to the floor, gotta pump it a few times to get pedal up then she stops like nobodies business. whats your guys take on this?
What is a little bit of drag? It sounds like the cylinders are not adjusted far enough out. It is taking too much fluid to push the cylinders all the way out, that is why you have to pump your brake pedal. Adjust the cylinder out until you cannot turn the wheel. Then back off a couple of clicks. You should get no more than one revolution of the wheel when you spin it.
The other option is that they were not bled properly. You could have air in the lines. Buy a brake bleeder kit to see if there are still air bubbles coming out when you bleed the brakes. The kits are cheap and make things much easier.
Good luck!
If the brakes "pump up", then they are not adjusted tight enough.
Remember, you have to tighten it until the drum is locked up first to fully seat the shoe, then back off 3-5 "clicks".
If the pedal feels spongy, then you need to bleed.
is it possible that im drawing air in one of my new hard line connections? ill try adjusting them tomorow. its not spongey it just goes to the floor then need a few pumps to get pressure.
No. They just need to be adjusted properly. If you have two cylinders per wheel, you need to adjust both of them the same way.
gotcha im all over it in the am time to sleepy............thanks pin_head
Drum brakes can be initially adjusted after they are worked on, but need to be driven a short period and used (up and down the street or even the driveway is usually enough) so that the shoe will be ‘centered’ on the drum, and then you will need to adjust them again, to make sure that you did not get a false adjustment from the shoe not being centered to the drum. Once you do this to BOTH wheel cylinders, you should have a pile of pedal and great brakes.
Good luck!
-Steve
thnaks steve i drove around the block after thinkin everythnig was adjusted and almost took out some shrubs. guess i was wrong ill try adjusting once again tomorow and see what i come up with.
I went through this nearly exact issue, and found that I had air in the system as I did no bleed the 2nd cylinder on the drums. :doh: bled them again (both cylinders) and POW- awesome brakes.
