Pulling Right Under Braking
Tulsa, OK
Website
www.cardomain.com
OK, so it's not the LCA that I suspected because it quit pulling while driving, but continues to under braking. Pulls harder under initial braking but relaxes somwhat under "hard" braking.
History: Went wheeling a week ago and got into some really deep sticky Mud (also bent LCA). Truck was pulling to the right so I investigated the brakes initially to rule that out. The calipers were totally caked with mud so I pulled them, cleaned em and lightly sanded the pads. Put it back together and it was still pulling right while driving and braking.
Today it is only pulling under braking. Help a brother out with suggestions:confused:
Would investigate the calipers more. Sounds like the left front caliper isn't working as well as the right. Possibly a kinked metal brake line.
The #1 cause of pull that I see is oil/grease leakage on pads/rotor, did you check all four? Do you feel the pull more in the truck or the steering wheel? Also check wheel bearing preload, if loose can cause a pull.
I got buried in some deep mud once and it sucked
My rig started pulling to the left shortly after.
It ended up be a partially frozen caliper.
Probably do to all of the mud that got jambed up in there.
Either way I popped out the stuck pistons cleaned and lubed them up reall good and put it all back together and it was all good and it has been 6-7 months since I did the ghetto fix.
Do not forget to use alot of brake caliper grease on the piston boots and back of brake shoes.
Good Luck hope this helps
Bumping this back from the dead as I have a related issue. I parked my 80 for about 6 weeks while I was out of town on work. Upon returning, it pulled left while braking. The pull was more severe as the brakes heated up and as more braking pressure was applied. The steering wheel would turn to the left as well. It drives straight when not braking.
The front passenger rotor and caliper measured quite a bit cooler than the driver side with an IR temp gun. It appeared one of the pistons seized on the passenger caliper. I replaced both front calipers with OEM remans. I left the pads and rotors alone as they have worn normally as far as I can tell and have plenty of life left. I spent an afternoon bleeding the system.
After replacing the calipers with OEM remans, it still pulls left while braking, and it actually feels worse now. The passenger caliper was about 25*F cooler than the driver side after a drive today so I am guessing it is still the culprit. Any ideas since I know it isn't seizing anymore?
Thread revival if 5 yrs. Wow.
^^^^take caliper you suspect off rotor. Have someone hit brakes. See if one of pistons is stuck. Easy as that. Do one by one. Mud usually gets in piston boot. That jambs them up easy. Napa calipers have great warranty. Also cheap to just replace and forget aboout it.
Thanks for the suggestions everyone. The pistons weren't seized or stuck. I easily compressed them before I installed the calipers.
The calipers I got from the dealer were just calipers; they weren't loaded or semi-loaded. Guess I didn't clean up the old brake pins on the passenger sidewell enough before putting it all back together. Clean new hardware solved the problem.
