PS Bracket picture
I used Bill Dorry's, but I did not know about Mark's at the time. I think his uses the smog pump mount or the alternator mount, either of which may let you keep the F aircleaner. Mark's stuff is always good, I just have not seen one.
I do not like the ones that use the head bolts. JMO
Ed
Samper I'm hoping you get some pics of the bracket. I am contemplating Bill Dorry's bracket for the box and Mark's for the pump so that I can retain my stock air cleaner in my 71 F engine.. I talked with Mark And his will allow you to keep the stock air cleaner however he does not provide anything for tensioning the pump. Would love to see some pics of how others have addressed this.
Tensioning the pump should be a simple matter of using a piece of another bracket that is basically a piece of strap thet has a hole in one end and a slot in the other. One end goes to a bolt on the waterpump the other to the pump. you can see them in the pic I stole from the other thread.
I have a couple laying around if you want them.
Ed
I saw that pic. Not sure but it looked like about 15 washers on the water pump to get the bracket to align. Next?
I thought your question was about tensioning the pump. I answered that question, or can you not see it?
Next question.:flipoff2:
Ed
And replacing the bolt on the warerpump with a stud and three nuts will space the tensioner nicely.
Best pic I could find of my old pump set up....nothing fancy....
Piece of steel bolted to the front of the pump...it has a hole in it with a nut welded on the back side for the adjuster/tensioner bolt.
The arm piece that attaches to the water pump is from a earlier 2F smog pump set up, iirc.....
Steve, where do you get the insulating sleeve that you have around the PS lines? Or is that for abrasion?
Ed
Denol, oh I see it alright, just don't like it. Two tension brackets bolted together and the spacers don' get it. Just thought somebody else might have a little better solution.
In the accompanying text, Jody remarks about the inelegance of the tensioner:)
Using a tensioner of proper length and shape would eliminate all that fugliness.
I have no 15 washers. Where necessary, I used a spacer made from pipe.
Ed
Samp, here are the two brackets....take your pick. The top one is off a Vulva and the bottom is either alternator or smog pump from a '40.
Ed
Ed
The stuff that I have is a Caterpillar thing, but this is used by many manufactures....It is an abrasion resistant nylon sleeve....Let me know ho many feet you need and I will send you some bud....oh and PM me your addy again... :)
:beer:
