Well, H55F's are "almost" a direct fit. You will still need a bunch of things like a clutch pedal, clutch master, lines, slave, fork, etc. Along with late 2F (marked 3F) bellhousing.
62s have the 4speed auto with OD (A440). 60s have the 4 speed manual withOUT OD (H42). Beno said the fancy 5 speed manual with OD (H55) will bolt right up to the fj62 3FE engine so I'm 100% sure it does, their just expensive ($2089). pretty sure they bolt right up to 60's 2F as well.
If you want to swap an H42 in to a 62, you'll need to get it out of a late model 60 (1986-87) because they have a spacer type thing on the back that makes them as long as the A440 automatic.
As much as it pains me to say it, 80s are probably the best truck if you have expo in mind... but their still ugly as s***! (anybody wanna help me swap woody's body onto Aidans 80 frame/drivetrain/suspension?)
I believe most of us have a 30 day vacation under our beltsWatch what you wish for! There could be a few 30 day suspensions coming----LOL
Can we get this cleaned up so its useful tech for future cruiser heads. Things went way out of hand after my post but I was being somewhat serious about stopping all of it. So can a mod clean this up? Thanks
I believe most of us have a 30 day vacation under our belts. The red truck you are talking about is it a 60 or 62?
It's still useful tech info. The added lil play time keeps us A.D.D. Ppl reading lol.![]()
But really I don't have a delete post button so who has to do that ?
Sent from my iPhone back on the road.
Guess it makes you feel tough. Eh to each his own. Fuel injection is more reliable at angles and cold start up than carbs. Once again to each his own.
Molon Labe
Either way never try and convince yourself that your build is finished........cause it never is.
The A440F is longer than any version of the H42. The H42s in the 85+ FJ60s are the same length as the H55F, and a direct fit. Shift tower on the H55F is a little bit taller than that of the H42 so the installation requires just a bit more finesse. Installation of any manual into a FJ62 will require driveline, cross member modifications, along with adding the stuff needed for the clutch. And a little wiring job with the neutral start switch.
For myself the 60 series is what I've settled on for day to day use. I think the best 60 series, if you want to stay Toyota, would have to be built. Later FJ60 with 2FE and H55F. Go for the FJ62 front axle with the factory trussing and vented backing plates. Suspension of your choice, OME is good enough for my use, and tires and gearing. The H55F, 4.11s, and 33s work fine for general use.
Well I don't have a lot to add I own both types FJ60 & FJ62 and depending on what purpose the vehicle is going to serve. They are both great vehicles the FJ62 is a camping rig really doesn't see any trail time. The FJ60 is modestly built for camping fishing and trail riding but as already mentioned it's big and heavy for some of the rougher trails. If heavily modified it's more than capable on any trail. I've never been to terribly concerned about a little sheet metal damage. The musts for me and the mods made to my truck are are Bumpers, Sliders (Thx Nick), Full Float rear axle, 35" MTR Minimum, Regear diff's to 4.88's
FJ62 Front Axle with Chromoly Super Set Shafts and Birfs (Future Upgrade), H55F
5 Speed Manual Gearbox, CB, TBI (Future Upgrade) and odds and ends. To each is own, buy the truck you want drive it, take it camping, take it wheeling, decide which direction you want your build to go that best suits you needs. In a few years it may turn into a tubed wheeler or be pretty much with what you started with. Either way never try and convince yourself that your build is finished........cause it never is.
Thanks for the input guys! Yeah if I got one it would def end up on 37s and all that comes with it. I want something to take the family in and go camping but I also plan to go wheeling and won't be taking the bunny slopes. I know I damaged a good bit of sheet metal on the FJ cruiser but back then most of the group was on IFS and few were on solid axles and they were mild builds. I guess it comes down to deciding what to do and if the red cruiser is for sale when my taxes finally get deposited and got the money laying around. I know it's heavy. My fj cruiser was probably pushing 5500 or 6000 pounds. It did alright.
But the real reason I'm trolling on the Georgia club board is to see if any of you know a sergeant at Fort Benning with a white 80 series that has an ARB on the front and a Slee bumper on the back?
