It was the size of a short lived model called an fj62 from 88 to 92 I think. Loyal following but less on the road. This is a popular size in other makes though. Burbans Ford's and a lot of 80's era rigs
Yessir, I am working on a plug and play solution for the round headlight members.
I am very interested in the JWSpeaker kits for my FJ62. I found them back in August but was blown away by the expense. Was even considering a conversion to round headlights so I had better options but it looks like once all the costs are factored in, it's a wash, or worse.
My FJ62 has three of the four (don't ask because I don't have an answer) forward lights converted to Hellas and I still can't tell if my headlights are on if the streetlights are also on. Then again, the conversion was done by the PO and is likely quite old.
--Allen (mobile)
I have a set of these: http://www.amazon.com/Rampage-5089925-Halogen-Conversion-Headlight/dp/B001OMPJGS/?tag=ihco-20
They work pretty well.
These might be of interest to you: http://www.dapperlighting.com/collections/accessories/products/cree-led-headlight-bulbs
It's hip to be square.![]()
Okay, those are cool...
Any comparisons on the difference in lumens from these to the projection lights?
I have the same rampage kit running PIAA bulbs, might be interested in these depending on the output. Any chance you have comparison shots like with your projectors?
DapperLighting offers a great solution at a low cost. I really like those units. However there is one downside, and not a lot of people realize it until it's happened to them...
H1 HID bulbs are aftermarket only, there is no OEM H1 HID bulb. So that means if you have a ballast failure, bulb failure, etc, you cannot get a replacement unit on the fly. I bulb headlights for customers and ONLY use equipment that is compatible with OEM HID equipment. If you have a failure with one of my setups, you can stop in at a dealership (Lexus, Mercedes, Audi, BMW, etc) and pick up a bulb. The same goes for the ballast. This allows you to replace components while on a road trip if one fails.
The downside to this? The cost is much higher, and space is a lot tighter as the components are larger.
Finally got some 4x6" in stock. You can check them out here:
http://www.dapperlighting.com/colle...ducts/dapper-lighting-4x6-projector-headlight
Light output is decent. Definitely better than stock. Not bad for < $150...
Is the cost the same for a right hand drive model?
Ben
I like these. I have a set of Trucklite LED 7" replacements on my 60. They froze over on a recent road trip, so they are coming off. I was not happy with the high beam on them either. Is the heat produced by these lights the same as the Trucklite LED's? I noticed a very defined cutoff in one pic in the shop, and not so much in the pic against the garage door. What is the difference? I have to admit your prices are also way more competitive than I expected - kudo's!
Didn't see the confirmation in the string. Does this require any mods to get it to fit into the FJ60? love the light output from them.
2000UZJ thanks for the note, well said. For now, I will be going back to halogen, because $$
