Project Hundy Build Thread - 2000 UZJ100 Land Cruiser (Deathstar)
Ok, ok. Looking forward to part two. Been peeking at the picks on Canguru Racing. Congrats on your finish at Baja!
Thanks!
Death Star Build Part# 2: Choosing components
OK, so in the introduction of my build thread I explained my build plan based on the combination of my wants and needs. Balancing wants with actual needs can be a foggy proposition, with some items clear cut and others not so much. I spent some time looking back to my Tacoma build and use, its modifications and expanded from there. With those listed it was time to expand on each item and start detailing the specifics, brand, style, size, etc. I'm going to do my best to be un-biased here but its fair to say I choose parts not because I sell them, but I sell them because I choose them personally. At that you will note that many of the parts come from a select few manufactures. This isn't to say these are the only 'best' options, I'm not implying that in the slightest. Rather, I'm hoping my selections will prove the 'best' option for my build.
ARB Front & Rear Bumpers - While there are a handful of great 100 Series bumper options on the market, I'm a fan of the function and form of the ARB units. Having installed dozens in the past I was 100% confident they would suit my needs. ARB offers two model bumpers for the front of the 2000 UZJ100, the Sahara bar with the optional chrome upper tube and the standard combo "commercial" bar with the full upper hoop arrangement typical of the standard ARB look we are all accustomed to. I chose the traditional commercial model bullbar (ARB Part# 3413050) preferring the upper hood protection and ability to run the the ARB Side Rails. ARB rear bumpers are offered in a modular approach, you start with the base rear bumper (ARB Part# 5613210) and have the option to add a left or right tire carrier, left or right jerry can carrier, or if carriers are not fitted you run a cover panel. I chose to run the spare tire carrier (ARB Part# 5700211) on the left and the jerry can holder (ARB Part# 5700222) on the right. I chose to run the tire carrier on the left as this is a US spec LHD vehicle and I'd rather not have the tire blocking my visibility when you look back over your shoulder. The ARB rear bumper features double shear swings, strut openers and safety lock-out in the open position. The bumper has an integrated Class III hitch and tail lights and turn signals to accompany the stock lights which are partially obstructed by the spare tire.
ARB Side Rails & Step/Sliders - I was a bit torn on what to do for slider/steps, there are plenty of fantastic options on the market but I wasn't 100% sold on any of them. I've had side rails installed on my FJ40 since we built it over nearly 12 years ago now, while there have been numerous occasions I would have wished for a narrow 'rock-crawler' bumper offering more clearance and approach, there have been far more in which the side rails and heavy duty front bumper really saved the day, saving fenders, etc. Given the fact this build will likely never see a trail like Pritchett or the Rubicon, the minor loss of clearance from a heavy duty front bumper and side rails is a non-issue. With that in mind, I chose the the ARB Step/Slider (ARB Part# 4413250) which allow use of the ARB Side Rails (ARB Part# 4413260) which tie the sliders to the front bumper. My experience has shown they are a great fit and will meet the needs I have for this vehicle. If I wasn't planning to run the ARB Side Rails, I may have gone a different route with the step/sliders but I'm confident these will do the trick.
Warn Winch - My experiences both in the shop but more importantly out on the trail have always left me with nothing but respect for the Warn product line. Anything can fail but its my experience that you see fewer failures with the Warn product line and if/when they do fail, you have their rock-solid warranty to get your winch back rolling (pun intended). I've had a couple of winch failures over the years, both winches were very heavily taxed and neither left me stranded. Warn took care of me in both cases in under a week. So which Warn? I'm a proponent of choosing a winch that is at least 1.5 times the weight of the vehicle. Given a 6,000 lb dry weight I was looking for at least a 9,000 lb winch. As Warn no longer offers the M10000 model, I chose to try their value line winch in that rating, the VR10000. It offers a remote solenoid which is needed for the installation in a 'feet-forward' ARB and its housing dimensions don't require any spacers or modifications to the bumper itself.
Safari Snorkel - There are a couple of snorkel options on the market for the 100 Series platform, again bases on access and my past experience I chose the Safari Snorkel (SS86HF) for my build. It provides a true water tight fitment with clean lines and a snug mount against the fender of the 100. This new design allows the power-antenna to stay in place and it sits several inches lower than the previous model as well, win-win for my needs.
Old Man Emu (OME) Suspension - Ride quality, load capacity and height would all need to be adjusted with this build. I've put hundreds of thousands of miles on OME equipped Toyota's, again other options exist but for my planned uses the Old Man Emu setup is truly the best of breed in terms of performance, longevity and reliability. For the front I chose Old Man Emu torsion bars (OME Part# 303001) matched with the heavier front OME Nitrocharger Sport Shock (OME Part# 60001). In order to bring up the rear ~3" and substantially increase the rear load capacity I chose a 'heavy-constant' OME coil (OME Part# 2864) and again matched it with a heavy load OME Nitrocharger Sport Shock (OME Part# 60003). In order to reduce the potential for damage to the rear shocks, I chose the OME Rear Shock Stone Guards (OME Part# OME661). To prolong CV life on the front end, I chose the Slee Diff Drop Kit (Slee Part# SOF1047).
National Luna Charging System/Optima Battery - With the plans for a 12V fridge, multiple extra 12V outlets, HAM & CB radios and the potential for this vehicle to sit for several days, a dual battery system was a must. I've sold or installed a half dozen different types of dual battery management systems over the years but again I went with the same one I recommend to my customers and the same model I'm running currently in my Tacoma, National Luna (Nat Luna Part# NLS355). The National Luna Intelligent Solenoid makes for zero input operation, automatically connecting and more importantly dis-connecting the batteries based charging characteristics. Additionally, the in-cab controller allows the user to monitor the the voltage of both batteries, pair them manually, turn on or off the over-voltage and under-voltage alarms, etc, very user friendly. So running dual batteries will require a customized mounting for the auxiliary battery, while I've built a handful of custom units including the setup in my Tacoma, when a good product is on the market its often far cheaper to go that direction. Enter the Slee dual battery bracket (Slee Part# SOF1251), its 100% ready to bolt in and accept a standard full-size battery of your liking. Now to the batteries themselves, opinions here vary about as widely as tire selection. I've been running Optima's in my FJ40 for nearly 12 years, Odysseys in my Tacoma for over 5 years and a smattering of others in other rigs I've had. Given my ability to run a full size battery and my need for one standard and one reverse battery, I opted for the Optima Yellow Top in the auxiliary position and the Optima Red Top in the starter position.
Helton Hot Water System - This is truly a case of finding a product I used personally to be so above par that I later became their US distributor. The Helton shower products use a hard mounted heat exchanger to 'borrow' heat from your engines cooling system to in turn heat fresh water. The magic happens inside of their 100% copper tube-in-shell heat exchanger which is one of the most rugged and efficient options on the market. For my system I chose the Helton Hot Water (Helton Part# HW1) Heat Exchanger. I'm running this same exchanger in both my FJ40 as well as my Tacoma and its proven a fabulous component. The Helton will be mounted somewhere on the firewall using the rubber insulated clamps (Part# HELCLAMP) and plumbed in line with the 100's heater control system. Fresh water hookups will be mounted at the front bumper utilizing the Helton supplied bumper kit, thus allowing shower operation without having to even open the hood.
Slee Skids - There are not too many options for 100 Series skids on the market but one won't be left disappointed with the quality of the Slee Offroad option. I opted for Slee's full skid system, if there was something vulnerable under the vehicle and I had an option to protect it, the choice was made for me. The Slee kit consists of a steel belly plate (Slee Part# SOF1121) that replaces the stock transmission cross-member, and a front and intermediate skid. For weight savings I chose the aluminum front (Slee Part# SOF1157) and intermediate (Slee Part# SOF1157) skid plates.
Wheels & Tire: My needs and planned uses dictated a tire that would not only provide durability and adequate traction off-road, but fantastic road characteristics as well. I've had fantastic results with the BFG All-Terrains on previous vehicle and they seem to provide stellar results for similarly built 100's as well. I decided to give them a go. There are not many options for wheels on the 100's 5 lug pattern. The truck came to me with a set of 20" Tundra wheels installed as well as a loose set of 18" Tundra wheels. Along the way I also acquired a couple of sets of 16" factory wheels, identical to those that would have came on this Land Cruiser when new. Based primarily on the tire options and second the aesthetics, I chose to go with the factory 16" wheels. Having narrowed down on the 16" wheel size it was time to choose a tire size. I solicited recommendations amongst our local 100 Series customer base and the 295/75R16 size kept popping up. It was decided, I'd run the 295/75R16 BFG AT on the factory 16" Land Cruiser wheel.
IPF Lights - I wanted a combination of long distance spot lighting as well as a broad drive lighting immediately in front of the vehicle. Given this criteria the IPF900XSDSCS Combo kit consisting of a spot as well as a driving light was a natural fit. I may switch things up a bit as new lighting options become more readily available but for the time being I think this will be a great option.
Landtank Fan Clutch - All the additional gear and payload is going to add a fair amount of stress to the stock drive train. While the stock 2UZ-FE engine and cooling system is fairly robust and very durable, one can always benefit from better cooling capability. One of the easiest ways to improve cooling on an older system is to refresh the fan clutch, either with a replacement or a rebuild. Better than a stock rebuild or replacement is the Landtank modified fan clutches which offer increased cooling performance. Landtank modified units have gained quite the reputation in the community for dropping temps back to 'normal' levels amongst heavily laded Land Cruisers. Given the planned uses of this rig as well as the hot temps throughout Utah's summers, particularly in the desert environs it ill frequent, the Landtank fan clutch is a no brainer in my opinion.
Roof Rack - Any load on the roof can be a hit on aerodynamics and thus fuel economy not to mention vehicle handling due to the weight. In an attempt to best minimize these effects I wanted the lowest profile rack I could find. The new Eezi-Awn K9 rack series offered exact what I was in need of, low profile, strong and its aluminum extrusion track design offers infinite mounting locations along the top of the rack. This rack will offer unparalleled flexibility in the way the Land Cruiser is loaded, allow for the potential of an awning or roof-top-tent to be mounted and can be removed in a matter of minutes if not in use for extended periods.
Storage - There are several high-end rear drawer systems on the market, with some fabulous customer feedback I chose to go with a relatively newcomer to the US market, the ARB Outback Solutions setup. This setup allows flexibility on where and what you mount, all while maintaining a custom fit look by using their vehicle specific fit kits. I chose to configure my setup with a roller-drawer (ARB Part# RD1045US) on the right and a roller-drawer with a roller-floor (ARB Part# RDRF1045US) on the left side. The roller-floor on the left side will allow for fridge mounting and access. I chose to mount the fridge on the left side for same reason as the tire, visibility for the driver. Along with the drawers, ARB offers a fit kit specific for the 100 Series that covers the sides and back gaps making a custom fit. The plan is to us ARB's Fridge Tie-Down Kit (ARB Part#
Next Up: Parts Parts Acquisition
Looking forward to seeing this one in person.
Was unaware of the OME Lower Rear Shock stone guards - nice touch.
Kurt - are you staying with the front diff as is per your build plan, or down the road going to add a front locker?
I could have used those a few years ago. We were driving the Pony Express route to Wendover and I threw a huge rock from the front tires into the left rear shock. It smashed the shock and ricocheted into my brake caliper blowing my break line off causing all the brake fluid to bleed out and I lost full brakes. Had to make a improvised trail repair to make it to Wendover to get parts to fix it. Those guards would have helped for sure.
...Was unaware of the OME Lower Rear Shock stone guards - nice touch.
Yup, in stock at your local Cruiser Outfitters location :D
Undecided at this moment. I'm going to install a factory e-locker rear and possbily re-gear. If I do re-gear then I'll likely do the front ARB (and possibly do the rear ARB) at the same time. We just returned from a 4500 miles roundtrip with 4 adults, gear, food and spares and it wasn't as anemic as I imagined. Of course spending the majority of that time at or near sea level could have something to do with it. :D
Man, that is a random break. Crazy. Well, when your ready for them, you know where to find them :D
I installed ARB lockers and did not regear. Running the same 295 BFG's you have sighted in and I could not be happier with my decision. This 4.7L still has enough power for me.
Also have not seen a factory e locker install. I wonder what the technicalities involved with that project are...
Sent from my droid
Kurt-
Great gear selection. I can tell you really did your research. Very few items on that list that I would change and those are specifically due to the type of wheeling I want my truck set up for. I'm looking forward to seeing the detailed install of the Helton.
... Also have not seen a factory e locker install. I wonder what the technicalities involved with that project are...
Sent from my droid
We will do a full rear axle swap, i.e. source a used axle with the OE e-locker and swap it for my open axle.
Kurt-
I'll make sure to cover that install, zero factory hoses cut and I can use my factory dash temp control valve for adjusting the output temp of the shower.
Sounds cool... looking forward to seeing it happen. What's your reasoning over the ARB? Reliability?
Sent from my droid
Sent from my droid
Availability, as for reliability I'm every bit convinced the ARB locker will satisfy my needs there. I think my latest plan is this:
1. If I re-gear, then I'll do ARB's F&R
2. If I stick with the 4.30's, I'll do the e-lock rear and an ARB front down the road
The Death Star hundy owned the ExpeditionUtah 'Freeze Your Tail Off' trip, couldn't be happier with its performance. I was on total cruise control this year with Stephen out in front this year, this let met get a few miles behind the group and have some 'spirited' driving opportunities to catch up in the tail-gunner spot. While the washboard was as brutal as I've ever seen it along the route, I was completely happy with how the 100 handled, this with a pretty decent load and full pressure tires. While it doesn't have the get up and go of the Tacoma, I had fun behind the wheel on the long sections of washboard rail road grade. We ended the day at the Spiral Jetty, my brother snapped this shot:
PS, Part# 3 of the Death Star build thread is getting close, been a busy few weeks :D
Death Star Build Part# 3: Parts Acquisition & Install/Build Planning
The collection of build parts lined up & ready for install
So with a build plan set and my list of needed parts refined, it was time to get all these parts coming and set them aside for the build time. I didn't have a set date for the build but I didn't want to pass up an opportunity because I didn't have all of the crucial parts on hand and ready to go. Time to get on the ringer.
The ARB parts were the easiest for me to line up, as we get weekly/bi-weekly stock orders via truck freight from ARB. Over the past few months I was able to sneak a bumper on the order here and a side rail kit there and before long we had all of the big components in house. The smaller items such as the ARB CKMA12 compressor and snorkel I could pull out of inventory (yes, even I have to pay for them ;)) and set them aside for the build. Over the course of 4 months I had a front bumper, rear bumper, snorkel, slider-steps, and side rails - all tucked away on the top level of some pallet racking in the shop.
ARB Stockorder, it's like Christmas over and over
My next call was to Paul at Equipt Expedition Outfitters. Eezi-Awn was ready to launch their new low-profile K9 roof rack lineup, and Paul had some on a container headed for the US, so I made sure my name was on one. Paul is also the distributor for the National Luna product line here in the US. Cruiser Outfitters stocks the National Luna Dual Battery kit, so I was sure to have a spare on the shelf that I could use for the build. Not only did Paul make sure my name was on an incoming rack, he was quick to say "what else can I do to help with the build", and if you know Paul you're not surprised. Paul has been a long-time friend, a long-time customer, and a long-time supplier of ours. Paul was a pioneer with the 100 Series platform and has put hundreds of thousands of miles on his well equipt (pun intended) 1998 model. I've had the opportunity to help Pal outfit his 100 over the years as well as travel with Paul on many of his adventures. It's 100% fair to say his 100 Series capability, reliability, and functionality was a major driving force in my adoption of the platform. (Check out his build thread here)
Paul May's well build 1998 UZJ100
Armor Coatings was really a shining star for me. Utah has a bunch of good powder-coaters, and I've had fair results from a few different ones, but the guys at Armor really stepped up the game in quality and timing. In just a couple of days I had powder-coated factory LC wheels, lug-nuts (which required them to make a custom fixture), roof rack mounts, step deck plates, and the rear bumper top plate. This wasn't a huge order for a production-capable power-coating facility, but still they treated me like their only job. I've since been back with a handful of other small jobs for my FJ40, and jobs here in the shop, and each time the results are the same: fast, quality and affordable... three words that don't generally get used in the same sentence.
OE 16" wheels powdercoated by Armor Coatings
Christo Slee of Slee Offroad lined me up with a good chunk of the parts I needed for the build. With a 5 minute phone call I had Slee's dual battery tray and full-suite skid plate system on the way. Christo is a pioneer in specialty components for the 100 Series platform so when it came time to outfit my own, the choice was a no-brainer. I quickly outlined our build plan and the idea to accomplish all of this in a weekend. Christo replied with a joking "good luck, my guys would hate me" and some well wishes. He made sure they had the parts in stock and let me know they would ship the next day, something you can count on when you hear that from Christo or Ben. Along with their incoming skids and battery kit, I had the Slee diff drop kit in stock and made sure to set one aside for the build. My suspension needs were now satisfied, my armor needs were now satisfied and my dual battery system was only waiting on the batteries themselves.
Slee skid plate system (Photo courtesy of Slee Off Road)
Tires are often one of the more emotional build decisions one is faced with. There are so many brands, even more styles and sizes, and most of all, opinions. I had previously decided upon the BFG All-Terrain in the 295/75R16 size, and now it was time to pony up. I called my tire guy Jared, at Big-O Tires in Sandy, not far from our shop. I'm a big advocate of developing a working relationship with your local tire guy, and Jared is my tire guy. Whether it's an alignment on a customer's freshly lifted Tacoma or a last-minute tire balance on my FJ40 before a trip to the desert, Jared and his crew always take care of me. We started with some loose factory 16" wheels and tires I picked up from some local Cruiserheads (thanks Corey & Cameron). They stripped the old tires and we got the wheels and lugnuts over to Armor Coatings. The next day the wheel and lugnut powder-coating was complete, the new BFG's were on the shelf at Big-O, and we just had to get them both in the same place for mounting and balancing. All too easy.
All mounted & balanced @ Big-O, Ready for the install
I had intended to order the winch through one of my regular vendor channels; however, I stumbled across a great deal through a local private party seller who had a new-in-box Warn VR10000 just a few miles away. I'm a fan of any winch, so long as it has a "W" on the control box :D Now I know there are some other great options on the market, we've installed about one of every reputable winch on the market in the shop, but having run Warns on all my previous rigs, I wasn't willing to hamper what has proven to be a near spotless track record. I've actually had two winch failures, one on my FJ40 and one on my first Tacoma. Neither failed to complete the recovery, neither left me stranded, and above all, neither cost me a penny for the repair due to Warn's lifetime warranty through Six States, our local Warn authorized winch repair facility here in town. Anything can break if taxed hard enough and often the merit of a product isn't if whether it breaks or not, but how it is dealt with after. For that reason I had no reason to look elsewhere with this new build. The VR Series is a more recent 'Value' offering in the US market, my experience thus far was all positive with the series, easy answer.
Warn VR10,000 awaiting install in the ARB Winchbar
The Helton Hot Shower was another 'off-the-shelf' item. As I mentioned in the previous installment I opted for the Hot Water unit, which offers hotter water and more flexible uses in the future. The full setup consists of the Helton hot water heat exchanger, the heat exchanger mounting clamps, the bumper bracket, and the 12V shower pump/head. In addition I needed to source coolant hose to tie into the factory cooling system and the 1/2" fresh water hose, which can be found at a good auto parts or hardware store. In my search I stumbled across red and blue 1/2" options from a local hose supplier; they are rated for the appropriate temps, safe for use with potable water, and the red and blue color coding are welcome additions as they make for a tidy install. We will likely start adding the red/blue hose to our Helton kit offerings, or at least offer the hose by the foot for shower customers. The coolant hoses are a little more application-specific and more than that they are really specific to where/how you mount your exchanger. Because I wasn't 100% sure how everything was going to lay out under the hood with the dual batteries, compressor, auxiliary fuse block, etc., I opted to make the coolant hose components an on-the-fly parts need, easy enough to source during our build at the local auto parts stores.
Helton Hot Shower Kit
Batteries are seemingly as emotional a choice as tires, well almost. Browse internet forums and you'll find opinions based in every direction, and while I think there is much to be gained from the opinions of others, in some cases the momentum of love or hate can overwhelm the reality. I've been using Optima batteries in my FJ40 for nearly 12 years, never had one fail, never even had one go dead without good cause, they have just worked and worked. About 5 years ago I decided to replace them before a big trip just as a preventive measure, and the old one is now in my forklift, where it works fine as long as nobody leaves the key on :D. Along with Optima, I've had decent luck with the Odyssey (or their re-badege options) batteries. However, I literally had to replace the two Odysseys in my Tacoma (4 years old, just out of warranty) the same week as I was buying batteries for the 100 Series build. I hate to say it but the emotions got to me and I went back to the Optima. I chose a red-top for the starting battery and regular circuits and a yellow-top for my auxiliary battery, which will also run my secondary power system (Blue Sea Fuse Block). I sourced the batteries from our local Optima wholesaler, Battery Systems in Salt Lake City. The National Luna Dual battery kit comes with supplied connections, battery terminals and battery cable; however, I opted for a slightly larger battery cable gauge and thus my connectors all needed to be up-sized as well. S&H Terminal is my go-to for electrical supplies and specialty hardware, they specialize in bulk but you can buy small quantities as well. They stock battery cable (both black and red) in all major gauge sizes and you can purchase it by the foot. I keep a drawer full of battery cable build supplies in the shop, all sourced from S&H.
Battery Cable Parts Drawer @ Cruiser Outfitters
I placed a last minute order with Paul at PFran LED's Lighting for his 100 Series LED light kit. Paul was out for a few days (his wife was in the hospital) but he was quick to respond and in just a few days I had his well-assembled kit ready for the install. The kit replaces all of the standard interior bulbs with high-power LED inserts and also includes a few spares just in case you have a failure down the road. I was excited to shed some light on the interior (pun intended).
PFran LED kit tailored for the 100 Series Land Cruiser (Photo Courtesy of pfranleds.com)
Josh Vanderford from Ajik Overland Exchangehelped us out with the new to the market Landtank modified fan clutch. The fan clutch starts as an brand new OEM fan clutch and is specially modified using a high quality 15,000 centistoke oil. This thicker oil ensures lower engine temperatures, vital for keeping the 2UZ-FE cool with the additional loads and type of uses this rig will see. Additionally, the modified fan clutch offers better air conditioner performance but pulling more air through the AC condenser. I'd advise anyone building a 'heavy hundy' to consider the upgrade, just a phone call away. :D
Landtank modified 100 Series fan clutch from Ajik Overland
Last but not least was to make sure I had all of the various electrical components ready to go. Besides generic wiring supplies such as bulk wire, relays, heat-shrink, etc., I would also need a fuse block, 12V outlets, USB outlets, and a fridge outlet for the back. I opted for my standard choices: a Blue Sea Fuse block assembly, Waytek Wire & RaElCo for my wire, connector and heat shrink needs, and Will at Sierra Expeditions hooked me up with a couple of the new-to-the-market Blue Sea USB outlets that he had just got in stock.
Wiring Parts Drawer @ Cruiser Outfitters
Where can you buy all (most :D) these parts? Cruiser Outfitters of course! We stock the majority of these parts and can have the rest of them in short order. Wanting to do a similar build on your Toyota? Give us a ring and lets discuss it, we've specialize in fast service, and while this build was rather accelerated we have done similar builds for customers in under a week. We don't retail many of the parts used in this build, there just isn't enough demand for it but we are happy to install it as part of a comprehensive outfitting of your vehicle.
Now onto the planning, this is where I really geek out. I worked to develop a list of nearly 200 tasks that would need to be completed during the build, some dependent on other items, and some have dependents waiting on completion. With the list developed I was able to build a Gantt chart which visually dictated the order of operation that would need to happen for all of the components to make their way on the vehicle. While this might be a little over the top for some, I think it's a wise way to prioritize your limited spare time whether you plan to knock out the build in a short time period (like a weekend :D) or over the course of several months or a year.
The weekend agenda, already knocked off a few items by the time a photo was snapped
With the Gantt chart refined and finalized, I tuned the project down to ~50 major project task headings and transferred them to the dry erase board in the shop.
Next Up: The Build
Subscribed; should be fun to follow!
nice build. A little of topic, but I am interested in why you chose a 100 series over an 80 series and what you see as the trade-offs between the two.
Subscribed.
Looking to buy the :princess: a 100 and wouldn't mind following in your footsteps when I start "tinkering" with it :D
Great question, I'll do my best to answer. I've owned an 80, it was a short period and an FJ80 but I've driven/co-driven dozens of others (Baja and back in a SC'd FZJ80 last year and a FZJ80 the year before). Fabulous rigs, fabulous. However this 100 will replace my Tacoma, not my Tacoma and 40 ;) If I was trying to build a one-size fits-all rig for long distance trips as well as light trail duty, the 80 would likely be my choice. Then again finding a low mileage unmolested rig is getting harder and harder. However this 100 will replace my IFS Tacoma that is primarily used for long distance 5-7 day trips, Baja, corner to corner state trips, etc. It will be rare that it sees rocks enough to warrant a locker for instance. So with that in mind, the speed and suspension (think high speed) is a welcome feature. Add the fact I can comfortably tow a trailer and I was sold. Clear as Mud :D
...Looking to buy the :princess: a 100 and wouldn't mind following in your footsteps when I start "tinkering" with it :D
Right on, glad someone is finding my drivel useful :D
