- Thread starter
- #241
Radiator installed. Had to trim around the support to clear the PS box.
Check out some of Dougal's post over on 4tbswap.com. He seems to be a wealth of knowledge in the turbo world.
Driveshafts are pretty. How long did the rear end up being?
neither, it is 58mmSo what is that, a 46 or a 50mm inducer compressor wheel?
No, look at operating point on the performance map, a few posts back; it is optimum for a 4.0L engine with about 80-85% Volumetric Efficiency
View attachment 1121690 View attachment 1121691 The new turbo looks huge!
Hi devil frog, I'm in the process of copying your turbo setup as it was when Akarilo had it and I'm wondering if you know how he fed the additional fuel injectors? Was there a second fuel pump or did he just T into an exsisting fuel line. Or maybe a fuel pump voltage booster? I read his entire thread and can't remember any answers to those questions. I will be using a T3/T4 like yours Instead of the smaller turbo.
I want to use the factory ecu to keep it simple and to keep the cost down. I've used megasquirt before and it worked good because I was making major changes to my 22rte and the stock ecu could never adapt. I got a good deal on the same additional injector controller Akarilo used and I really like the simplicity of it.
I will be removing the smog equipment too.
Megasquirt is good but it takes time and patience to get running smooth. It was my first time doing something like that and I felt like I was in over my head a few times. I would use it again only if I had to.
