Only thing left to do was hang it and wire up the lights and winch.
@rockstate45 was crazy enough to come and help me lift this monster onto the front of the truck. Thanks Jack! Got it bolted on, and headed out to the street for a winching session. With my 12 year old daughter at the wheel, I spooled the line in. Then finished wiring up the lights, as well as converting from a 12 pin to an 8 pin flasher and installing a Smart Tap flasher relay. Since the elimination of the factory bumper also removed the turn signals, I used some LED strips that function as DRLs until the turn signal is on, and then they light up amber with a runway effect for the direction of turn. I took these up the inboard side of the headlights and across the top of them. Also installed rear turn LED bulbs.
I still need to trim up the inner fenders and built a cover to go over the washer pump and wiring. the parralellagrams cut into the front under the lights allow access to the winch controls. The clutch is on the right, and the on/off switch for wireless and plug for the wired are easily accessed on the left.
