Build Project Bob
Only three right now fawkers :flipoff2:
looks like I am getting about 12 mpg.. not quite what I wanted, but the C6 is killing me.
I also am turning 3K at 70ish..
I am seriously considering dropping to 3.70 gears from the 4.11's. The dual tcases will give me plenty of crawl off road with the auto, and dropping the R's will be good too..
I also installed a tach int he stock hole, a radio (HD) and a CB.
Bob's coming together :)
You should get black face gages for the pillar.
12mpg ain't bad for a v8 60 with an auto. What were you hoping for?
I hit 75 (on the speedo) in second already.. Still pulling very strong. The motor is limited to 6250 rpm or so. I was probably at 5K ish.. Didn't have the tach hooked up at the time ;)
That is a 2 1/16" tach. Tiny, but fits the hole fairly well.. a fatter bezel would make a big difference.
I really wanted 15/16 mpg..
keeping my foot out of it would probably help lol :D
Spotted!!!
Hey Mace,
Saw you driving Bob yesterday!
You were turning north on to Durango off of Blue Diamond at 5pm.
I almost chased you down but we needed to get home.
Looked good except for the bondo!:D
yep, that was me, just stopped on by FOA shocks and picked up enough parts to convert my emulsion saw's to remote res units :D
lemme get my nitrous shot first ;)
I guess that means I'll need to put my roots blower on the front burner. That & a 200 nitrous shot, should leave Bob & his silly toyota axles in the dust :D
I just did a gear change on my buddy's Moser 9". It's running behind a very built 355 with a Weiand 672 blower & 200 shot of nitrous.... it should be in the 800hp range on the nitrous. Maybe I'll borrow it for our race ;)
In an FJ60?
In an FJ60?
It would be flat out scary in my 60 by the time I hit 2nd, but worth it just to beat Jason :D
Ofcoarse it was just a joke, but I think a roots blower would work out pretty good on my small block and probably safely get me into the 450hp range. The main advantage would be the lowend power provided by the blower that would be available right off idle. Too bad I'd have to have a scoop to fit it under the hood.
Thanks for the smartass useless comment :D
450hp in a heavy ass wagon is not that much. A few years ago I was on a trail with about 2-3 feet of wet snow where the Tbi350 would bog and completely stick the truck. If I would have had more lowend power , to keep the wheels spining and build momentum in the areas where I could get more traction it would not have been a problem and I could have made the trail instead of digging my self out and turning around 250 yards from the summit. I would never had made as far with my previously hotrodded 2f.
Point being, the way I use my wagon, I never know if I'm going to be in the rocks, mud, sand or deep snow. As long as you use the power only when you need it, than a 450hp engine would be just fine (as long as it has a stable idle), especially when it makes a ton of power (probably 250hp+) in the lower rpm's where its really needed. Just because you have 450 ponies at your command does not mean you need to always be using them.
I totally agree sixty.... I consider my 60 more a "extreme" expedtion rig. Does decent in every category and I can still drive it work. Having 450 ponies on tap would make everything more fun. :)
I would have made this puddle if I had 450...
