- Thread starter
- #81
Tires Installed
Angle shots
Angle shots
Josh83 said:Are you replacing your broken skidplate? If so mine is missing the door over the drain plug. Maybe we can work something out on the one from yours?
bull said:Not sure? The biggest one I can fit in the bumper I have. Maybe Slee could could chime in?
hoser said:Hey Bull--
It's 7:30am! Coffee break is over. Let's continue this Mod-Marathon!! Seriously, nice work!!
spressomon said:I think bull's got something stronger than coffee assisting![]()
SamoL said:Looks like the back didn't want to flex - maybe the springs are too stiff. It should be better, when you add some extra weight at the back.
Keep up the good work.
I've found out something new: that the stock shocks are (almost) the same length as the OME (well - except for the 74L, which is not ment to be used on a LC100). And if you lift the front higher, it will flex even less.
Regards
Samo
Regards
Samo
macneill said:This is awesome Bull! Just got back tonight and was looking forward to the progress!
