Project: Albert 99 UZJ100
Torsion Bar Install
Slide the Torque Arm back onto the torsion bar so it can easily be removed.
RH torsion bar installed
Can you make this out? Its a 19mm wrench around the top of the stock shock.
Get the wrench on top of the nut. Then spin the top part of the shock until the 19mm wrench is wedge against the frame. Then use the worst tool for every job to break the nut loose by slowly turning. This will destroy your stock shock, But easily remove the nut. Do the same to put on the new shock on but use your hands to spin the shock till you can't anymore then slowly use your gear wrench
Lift on..
So the lift is complete minus tweaking and some fab work for the back end (brackets and lowering the bump stops). After indexing the torsion bars and guestimating I was almost spot on. The front is exactly 1" higher without any adjustment. I will lift it up and adjust them to get the proper height. The rear came out 2.75" higher. I hopped on the rear bumper and it didn't budge at all. Quick test drive and no major issues. Better pics in the AM.
More to report tomorrow.
Awesome, awesome, awesone writeup. This is going to help me SO much when I install my stuff.
OK, for the rear. Isn't it basically the same as a FJ-80 install? I have never pulled the brake lines and the lateral control arm.
My trick is to do one side at a time and use a bottle jack to extent the axle enought to pull the spring and then ad the new one. I am wondering is that will work on my 100.
Can't imagine a better thread . . . thanks for taking the time to share your work and progress.
I am excited to see the bumpers go on . . .
Hey Bull--
It's 7:30am! Coffee break is over. Let's continue this Mod-Marathon!! Seriously, nice work!!
