What is your preference?
Oreilly's has the WIX 33092 available. I don't know if there is a better option....
if you want to be really cool, you could use the +1980 filter and bracket which are clear/blue.I run the cheap clear ones so that I can see what's going on in my fuel lines.
it is just a 2bbl. No EFIAre you running a regular carb or the Sniper kit?
I had that in-the-carb setup in my K5 from the factory and never liked it. Too small, and nowhere for the debris to shake out like an inline filter, so eventually the truck would buck from the filter staying clogged.I went searching for the fuel filter and could not find one. I talked with the guy that helped with the build and he stated that the fuel filter is in the Holley Carb.
Do i need to add one inline as well?
