*Update. After really not doing much of anything besides testing wires and fuses again I decided to just to put everything back together for now. So it's basically to where it was after the nav-delete. There is no stereo head unit installed. I then pulled the panel with the illumination switch off because I was just curious about the ignition switch. I know that the seller had swapped out swapped out the ignition cylinder before I purchased it. While I had the panel pulled out, I decided to start it up without looking at that ignition switch. Still no chimes/alerts but some of the gauges came back on. The gear shifter lights are now working, the fuel gauge (though I think it's not reading correctly), oil, and temperature. Oddly though the temperature gauge spikes immediately going straight to high. See attached photo.
I'm so confused at this point.
