power steering
Plant City, Florida
No doubt there are threads on this subject but if you know a good one I'd be interested.
My steering box needs to be rebuilt so before doing that I'm looking at adding power steering to my 3/76 FJ-40. Is this a bolt on process with parts off a different year or model or is it not that easy. Any suggestions?
mini truck is "essentially" as bolt on as you can get. Everything else requires welding and fab work.
There's a FAQ for that...
40-series FAQ
Sounds like minitruck would be a good option :hmm:
Even easier would be stock FJ40 power steering from 1/79. Need to source the shorter steering column but mini truck requires removing the steering box pedestal. If you were able to find a 79/80 complete power steering only part that wouldn't bolt on would be missing fixed nuts for clamp to hold the cooling loop on the front frame member.
Stock 40 series stuff is notoriously hard to find..
What 69LC said. If you're not going to rock crawl with it, the mini truck approach will work fine. If you do plan to rock crawl, then the mini truck won't really hold up.
I had the center arm rip out on my mini truck install while navigating on a black trail. Went to a 62 box and all has been good. Scout box and the Saginaw box are all good options.
If you go mini truck, Georg of Valley Hybrid/Cruiser Brothers has the mounts.
x 2 for 60 series.
I recently finished my 60 series conversion and it was 90% bolt on. Unfortunately my steering box leaks and I have not been able to test it thoroughly, but my test runs around the block have been great.
This is a very involved conversion, do your research and check out all the threads here on mud. I wanted mine to use all Toyota parts and planned to do this for several years, amassing obscure parts along the way. Hopefully my explanation won't be to confusing, in hindsight I probably should have taken more pictures.
I used the FJ55 steering column, early FJ60 Steering box, Toyota steering pump, high pressure hose, pitman arm and tie rod end. I replaced all my 40 series tie rod ends and also bought a new tie rod as mine was slightly bent.
I built my own custom drag link using a short portion of the old one welded to most of my old tie rod as the threads on one side perfectly match the FJ60 Steering rod end. I chose to do this instead of trying to source FJ70 series parts here in the US. I also used 2 early FJ60 series steering shafts which I cut and welded together to attach the FJ55 column to the FJ60 box. These 2 items were the only real fabrication needed for me.
Cutting off the old steering components was the hardest part of the conversion along with drilling the frame. I had previously installed an engine from an 87 FJ60 so the pump was completely bolt on. I did add a in line cooler to the return line to avoid overheating of the steering fluid.
Working by myself, this conversion took about 20 hours and the results have been amazing so far. 23 years of Armstrong steering is behind me now. My next project will be removing the box and sending it to west texas off road for a rebuild. This was the only downside of this swap. I had bought the box several years ago and apparently the seals shrank up in storage.
Apologies for the crappy pictures, PM me if you have any questions and good luck.
That is true, I also forgot prior to 1/79 the engine block was not tapped for the power steering pump. I have a factory power steering setup for my 79 which will bolt directly in except the steering shaft I don't have. Going with 8/80+ collapsible shaft which is easy to shorten. Easier dealing with grafting in the correct section of the firewall verses dealing spline section of the steering shaft.
There is always electric power steering too if Stock FJ40 steering isn't expensive enough ;)
@cruiserkev what did you do about interference with the radiator? I don’t see a spacer on your steering box.
Hard enough finding 55 series parts but 74 and 75 series are going to be even harder in a country that never got any 70 series. Another interesting thing in the US the FJ62 started 8/87. I show Australia starting 11/84. Believe yours had a carburated 3F with a H55F or A440F. We continued with the FJ60 and 2F until 8/87. Because of this our power steering pump bolt pattern changed while Toyota was still importing FJ60s here. I also see you show a Hilux part. Last Hilux we got was in the seventies and all those were 2WD.
No spacer or cutting of the radiator support was needed. I moved the whole radiator support bracket 1 inch to the passenger side by cutting off the 2 bolts underneath and drilling new holes. Used 2 new stainless steel bolts, reused the stock cloth pads and tightened it up. All hoses have enough flex to move this far and my fan shroud holes had enough space to move over as well. Works great and is quite strong this way.
Is it necessary to use 75 series steering arms & tie rods as per post #8 ?
Wondering if the shorter width of the 70 series verses the 60 series may be the reason. I know 40 60 series steering arms were the same if years were the same. If some 7X series were different on different years don't know. Tie rods lengths are different between the 40 and 60 series.
Arms are the same, but 70 series use the 60 series TRE's and it just makes life easier. Less to adapt.
But then you have to find the parts..
No, but if you keep your stock 40 steering arms you have to adapt at some point to the 60 box, which has a larger taper. There are several ways to do this including bushings and custom relay rods.
