Power steering just quit.
crosslake,mn
Website
forum.ih8mud.com
Was driving today and passed a slow vehicle after slowing down my power steering didn't work. I have read some old threads on power steering problems but don't have a good idea where to start looking. Any ideas? Thanks guys
Did you check the reservoir? Do you have fluid? Usually if a power steering hose goes it sprays everywhere.
What Chris said^^^^.
If you blew a hose, or the pump itself there would be fluid everywhere. Could also have been a slow leak that finally ran dry, have you noticed the pump groaning much lately?
Well, I had a small leak coming from the power steering pump. I had read about guys using Dot 3 brake fluid in the power steering to top it off because of the difference in properties of the Dot 3 make the seals swell. It was cold as hell out so I tried it knowing that my hoses all need to be replaced this summer anyway. That was 5 months ago. Has worked like a champ. Do a search on it. They explain it better.
Checked fluid level looks ok. Seems like I may have some power steering at higher rpms. Pump hasn't been noisy, by the way the rig is a 1995 FZJ80 with 240k.
Confirm that the harmonic balancer bolt is tight, ~300ft/lb.
In two old Chevys my PS pumps failed when the pump shaft sheared off inside the pump. From the outside it looked fine, it sounded fine, the fluids were fine, and everything spun fine I just had no power steering. I am not sure if that can even happen with these pumps (never had a need to look into it) but if nothing else checks out you might look into that. The easiest way I had to check it was to take the belt off and pull out on the pulley, it came right out with the shaft in tow. Again, not sure if this applies to a LC, but it happened to me on 2 different Chevys.
This!!
Both the power steering and oil pumps rely on the crank bolt, so make sure it's torqued to spec.
How do you stop the motor from turning over while you are trying to torque the crank bolt? Where do you get a torque wrench that will do 300ft/lb?
Just torque the snot out of it. Honestly I doubt you will overtorque it and shear off the fastener or something. The pulley has two bolt holes for securing it. Or you can use the at flexplate but that seems like a worse idea.
Do you just screw two bolts into those holes on the pulley until tight? Wouldn't happen to know the size of the required bolts? Is there a certain position the crank has to be in first? Wondering if there is a recess where the bolts go into? Sorry for all the questions but would like to start driving the cruiser again.
They are not through holes, they just give you something to grab.
Hey tools r us- just wondering I found my harmonic balancer bolt way too loose and I've had some moaning from the steering pump, I'm fixing it first thing tomorrow but what's the correlation? I wouldn't have thought to look there.
